18mm hex plug on upper oil pan
Ford does say use a long length ball-ended allen/hex wrench to remove the block plug to drain the passenger side coolant during a flush and fill. Could this be what you are seeking?
NOTE: Use of a long ball-end hex bit socket eases removal of the drain plug. Remove the drain plug and drain the coolant from the RH side of the engine block.
Install the drain plug when finished and tighten to 60 Nm (44 lb-ft).
Just crawled under my truck and there is a hex plug located just above the starter right behind the motor mount on the engine block. It is not visible from under the vehicle with the starter in place. It's visible through the passenger side wheel well. I could not access it to determine the size.
Milwaukee1979F150
24
06-18-2011 11:56 AM
