Sponsored by: Auxito
Oil plug question
Old Apr 17, 2011 | 07:55 PM
GANNET2's Avatar
GANNET2
Oil plug question
Had oil changed by local quick franchise, big mistake-- Took it to Sears for tires and another oil change turns out they could not fully remove the oil plug as it became very stiff while backing out and advised that they didn't want to continue because of possible damage to oil pan threads. I did see that they could loosen the plug almost all the way out with oil leaking from it, but it bound up at that point. Anyone else have this problem? Thanks
Old Apr 17, 2011 | 09:45 PM
sport truck xl's Avatar
sport truck xl
not a big deal, pull the plug all the way out and check the plug if the threads on the plug are jacked up then get a new one at any auto parts store, if the oil pan threads are jacked up, try a thread cleaner and if that doesnt work you can buy something called a pan saver plug that will keep you from having to replace the oil pan.
Old Apr 18, 2011 | 10:49 PM
Podaso's Avatar
Podaso
Avoid the problem in the future and change your own oil!
Old Apr 19, 2011 | 06:40 PM
galaxie641's Avatar
galaxie641
I've seen this on lots of pans just pull it and see, could just be a stiff spot for whatever reason.
garrettallison
Sep 12, 2008 05:49 PM
gustav129
Garage & Workshop
68
Mar 16, 2008 07:10 PM
ric01
Escape & Escape Hybrid
Dec 27, 2007 02:19 PM
seawulff
Aug 29, 2005 04:11 PM
BigMattXXL
Oil & Lubrication
21
Mar 20, 2004 10:53 AM
