Hi, I have an issue with some of the battery cable clamps in my Excursion, where they will not adequately tighten anymore. Got me thinking about just going ahead and replacing all my battery cables (positive and ground), and possibley the charge cable coming off the alternator.
Not that I would be forced to follow the OEM routing of the charge cable, but with all the wire loom on the charge cable it makes it very difficult to determine the OEM routing of the charge cable as a possibility. I would likely just cut the existing cable and leave it in place, but how is the cable routed?
Hi, I have an issue with some of the battery cable clamps in my Excursion, where they will not adequately tighten anymore. Got me thinking about just going ahead and replacing all my battery cables (positive and ground), and possibly the charge cable coming off the alternator. ...
Ours had a couple of positive post connections which just means they all corrode.
I replaced the cable ends with marine style connections and moved all the positive post connections into the gray electrical box on the fender just behind the neg battery post in the pic.
Added an aux power cable thru the marine breaker just behind the gray box to power a new fuel pump relay, GPS, gauges, etc.
Found all the parts on ebay.
I have replacedy BAT+ cable due to corrosion in the past. That corrosion was eating up alternators about every three months. Recently bought a new engine harness that eliminated the need for the bypass.
So, you need to understand that the BAT+ runs from the alt, into the big harness, runs under the CAC pipes, around the GPCM, over to the IAH relay, under the AC compressor, then over to the starter relay on the fender (00-01 models). Just before the BAT+ cable gets to the fender, there are fusible links.
You need to consider:
- take off/splice under spider for EACH plug of GPCM. These are 8 gauge legs.
- take off for AIH relay. Another 8 gauge splice/leg- provision for over-current protection to replace those fusible links.
I met all those provisions and ran a new wire with the above mentioned splices incorporated along with 300A fuse protection for psgr side battery. I then ran a second BAT+ off the post on the alternator over to the driver side battery with a 150A fuse protection. Ran an additional ground from DS battery to the alternator bolt/housing.
