Sponsored by: Innova
installing remote turn on switch
Old Sep 27, 2003 | 03:27 PM
tayz34's Avatar
tayz34
i forgot to run my remote wire from my kenwood cd player to my alpine amp so i want to do a switch for the remote wire from the amp. can sombody please explain what to do when switching the remote turn on. thanks for the help
Old Sep 27, 2003 | 03:50 PM
mikewrt's Avatar
mikewrt
you can do this a couple of ways:
1. you could just yank the kenwood cd and hook up the remote wire as it is supose to be done.
OR
2. find a +12v ignition wire (i.e. a wire that is only on when the key is in the run position) and wire the remote turn on for the amp to that wire you could put a toggle switch on this wire too if you would like to be able to manually turn off the amp. This will power the amp only when the key is in a run position. RECOMENDED!!
OR
3. Find a constant +12v (ie a wire that always is powered up) wire under your dash or where ever is convenient. then wire a toggle switch inline with this wire. DON'T FORGET TO TURN OFF THE SWITCH WHEN YOU TURN OFF YOUR CAR AND LEAVE!! This isn't the method that I would recomend as it is easily possible to leave the amp on when you leave your car and come back to a dead battery.
Old Sep 27, 2003 | 04:46 PM
tayz34's Avatar
tayz34
thanks for the help i just hanked the ken wood and did it how its supposed to be
Old Sep 29, 2003 | 08:29 PM
PrPlayboy's Avatar
PrPlayboy
Glad you went with pulling the Kenwood back out. Hooking your amp remote to a separate 12v source can sometimes cause a poping noise.
Doubleubar
Feb 24, 2016 06:33 AM
ride_red
2004 - 2008 F150
Jun 15, 2015 06:22 PM
schlepprock250
Jun 9, 2015 12:31 PM
tdappleman
Jan 6, 2014 01:44 PM
vdaily89
20
Jan 31, 2006 07:37 PM
