PLEASE HELP
Old Nov 30, 2018 | 06:46 AM
Edwardthc's Avatar
Edwardthc
PLEASE HELP
Brand new to the site, no clue where my post belongs. I'm in way over my head, 25 year old with no mechanical experience. I own a 92 f350 7.5l and it has sat for at least 2 or 3 years. Ran when parked. I was advised to clean the throttle body and gas tanks before even trying to start it. Won't sugar coat it, I'm clueless and in need of some major help. This is just to get it running. Plan to do alot more afterwards. Any replies on where to post or on the actual topic itself would be immensely appreciated.
Old Nov 30, 2018 | 08:17 AM
groundrat's Avatar
groundrat
Welcome to FTE! I think you are in the right place. First question is how much "fuel" is left in the tanks? Is it dual or single tank? There are a few methods for emptying the tanks, one of which is dropping them out of the truck. Another way would be to disconnect the lines from the fuel rail and direct the fuel through a larger hose to a catch can. You will need to replace the fuel filter after sitting that long as well. If the truck has almost no gas in it like mine did after sitting for 2 years, you can add 5 gallons of fresh gas and a bottle of B-12 fuel injector cleaner. If the throttle body isn't stuck, you probably dont have to clean it too much. If you decide to drop the tanks, be careful and do some searches on this site.
Old Nov 30, 2018 | 10:06 AM
BigBlue 94's Avatar
BigBlue 94
Get as much fuel out as you can and clear the lines with compressed air. Change the fuel filter and charge the battery on an actual charger. Wouldn't hurt to remove the plugs and shoot a little (very little) penetrating oil in each bore. Might as well swap the plugs too.
Since you will have cleared fuel lines, itll take some cranking to get fuel up to the engine before it fires up.
Old Nov 30, 2018 | 10:16 AM
jas88's Avatar
jas88
I recommend instead of cranking on it, just cycle the key from off to on several times and allow it to sit in the on position for 2-3 secs each time. This will run the fuel pump (listen for it to make sure your fuel pump is working - you should hear a whine sound from whichever tank the switch is on) for 2 secs each time. Check for fuel pressure a the fuel rail, once you start getting pressure, then try cranking it.
I second the recommendation to pull each plug and shoot a little oil in each cylinder. I personally use transmission fluid for this.
If you have fuel on the rail but it still will not start, shoot a little starting fluid in the TB. If it still won't start, you probably do not have spark.
Old Nov 30, 2018 | 10:26 AM
BigBlue 94's Avatar
BigBlue 94
Doh! I was thinking mechanical fuel pump, like my 85. Forgot this was efi and you could do it that way
Jbarth73
Jun 2, 2015 08:14 PM
mpbpulaski
Feb 16, 2012 03:56 PM
Cinda56
Mar 24, 2008 06:43 AM
supercab blue
Mar 11, 2004 07:16 AM
fordchickneedshelp
Nov 17, 2002 10:34 AM
