help!!!!
Old Nov 16, 2002 | 12:07 AM
fordchickneedshelp's Avatar
fordchickneedshelp
help!!!!
I am trying to move into my new home and my 89 ford E350 W/351 fuel injection will not stay running...it has spark, I changed the fuel filter...but the engine is getting no fuel... I can keep it running if I spray starting fluid in it but as soon as I stop it stalls...what do I check next? please someone help me
Old Nov 16, 2002 | 12:35 AM
bourbon's Avatar
bourbon
help!!!!
if it has dual tanks try changing to the other tank. it sounds like you have a fuel problem. your fuel pump might be bad, fuel filter plugged, or maybe even a fuel injector is bad.....except then i think it usually shuts the engine off and wont let you start it? not sure on that though.
Old Nov 16, 2002 | 03:01 AM
marragtop's Avatar
marragtop
help!!!!
It could also be the fuel pump relay under the hood.
Mike
Old Nov 17, 2002 | 10:27 AM
edenroadmaster's Avatar
edenroadmaster
help!!!!
if the pumps are ok, there is also a pressure regulator before the injector rails (if you have efi)
Old Nov 17, 2002 | 10:34 AM
edenroadmaster
help!!!!
