Factory Alarm system
Old Nov 23, 2018 | 09:29 AM
steve(ill)'s Avatar
steve(ill)
2013 Lariat .. I know if you lock the doors, then try to open them without the FOB the horn alarm will sound.
Twice in 3 weeks I have had the alarm go off while setting in the driveway with the doors unlocked. Both times, about 5 minutes after parking. All I could think of is DOOR SWITCH not making up so I sprayed all 4 door lock mechanisms with penetrating oil and slammed door 12 times each......... My question is, how can this happen when doors are not LOCKED ? I thought the system was not active until LOCKED ?
Old Nov 23, 2018 | 10:44 AM
alloro's Avatar
alloro
Does your system auto-arm after X amount of minutes?
Old Nov 23, 2018 | 03:26 PM
steve(ill)'s Avatar
steve(ill)
I really don't know if that's an option, but that would do it..... This is a 2014 lariat with most of the factory options.
Old Nov 27, 2018 | 08:57 AM
Pocket's Avatar
Pocket
Steve have you looked to see if by chance there's an aftermarket alarm wired in under the dash?
I've seen this before when vehicles are purchased and the owner never knows it has an alarm. If you bought it used then it could have been installed at any time. If it was new, it may have been a dealer installed item. If the dealer you purchased from doesn't add alarms, then it could have been a dealer traded truck.
Just some food for thought.
Old Nov 29, 2018 | 08:07 PM
steve(ill)'s Avatar
steve(ill)
I think what is happening is that I put the key ring in my pocket with 5-6 keys on it and ONE is bumping the ALARM button on the key... I narrowed it down to only happening when I put the keys in or take the keys out of my pocket... don't happen when they set on the table !!
Old Nov 30, 2018 | 10:15 AM
tiny1's Avatar
tiny1
Moderator & CL
Steve, I have had that happen to me but the key hits the horn panic button on my remote.
Old Nov 30, 2018 | 05:55 PM
steve(ill)'s Avatar
steve(ill)
YEP.......... that's it !!
Joneser5000
Dec 9, 2016 03:46 PM
63DH8
Dec 23, 2008 11:56 PM
97C5ENVY
May 11, 2007 11:05 AM
Fordmannn
1997 - 2003 F150
Mar 8, 2005 07:40 AM
heyers3
Mar 2, 2004 12:29 PM
