12 STX - Electrical / Lighting Remote Click
Old Nov 30, 2018 | 09:38 AM
TribSTX's Avatar
TribSTX
Does anyone know of can recommend an easy way to connect into the fuse or wire
that works the lights when key remote is clicked, I want that to be pattern
of LED lights im putting just above the running boards for additional lighting
when remote is clicked on off / unlocking doors
Old Nov 30, 2018 | 09:41 AM
ford390gashog's Avatar
ford390gashog
Connect to the side mirror turn signal wires in the lower kick panels.
Old Nov 30, 2018 | 11:08 AM
TribSTX's Avatar
TribSTX
I don't have turn signal mirrors
Old Nov 30, 2018 | 12:41 PM
rbentnail's Avatar
rbentnail
Have you looked into things called fuse taps? It's basically a fuse with an attached wire to replace the factory fuse. They're cheap & available at auto parts stores. Motorcycle guys use them for adding LED lighting just like you want to. Also makes it easy to find with a meter which circuits are energized in a particular instance, again just like you need to know.
https://www.autozone.com/electrical-...sories/32416_0
Old Nov 30, 2018 | 12:55 PM
ford390gashog
So this is a XL truck?
Old Dec 1, 2018 | 08:21 AM
TribSTX's Avatar
TribSTX
Yes I know what you mean issue is what fuse would this be, I cant seem to find which one it is
BlackbirdMfg
Electrical Systems/Wiring
Jun 4, 2015 10:30 AM
mike68gt
Dec 7, 2011 04:57 PM
LSchicago2
Feb 7, 2011 01:07 PM
Smitty1019
Apr 6, 2005 01:14 AM
lilman320
Nov 1, 2004 06:53 PM
