I`m having all kinds of problems ( hesitates bad on normal accell ) since I rebuilted my 460 ( 1996 E350 RV ) ,
I`m trying to find the ground junction point ( bolt or stud ) of the electronics sensors or pcm
I noticed in the "book" that there is a common ground at the PCM ,ICM ,PCM etc....But where is it ? Id like to check if it`s tight ...
thanks
Daniel
