where is the ground for pcm
Old Sep 29, 2011 | 07:21 PM
powerstroker100's Avatar
powerstroker100
Where can I check the ground for pcm, it appears its not grounding my gpr, can I manually ground my relay and leave it that way or is there a ground on the pcm I can check?
Old Sep 29, 2011 | 07:31 PM
woodnthings's Avatar
woodnthings
The PCM only grounds the GPR when the oil temp is cold. The ground is the aft small post on the GPR. If you are checking it with a volt meter or a test light it will show power as it is attached to the coil on the GPR. You can simply apply a ground to it for testing to check the GPR.
Have you verified the GPR is working properly? Usually they are the fail point.
The ground wire out of the PCM for the GPR is pin 101 on the 2002 trucks. Should be similar or close on the other ones. Look for the violet/orange wire.
Old Sep 29, 2011 | 07:49 PM
powerstroker100
which of the small posts do I ground to check if the relay is working? the one with the red wire?
I'll just rig up a wire and attach it to the battery ground then connect it to whichever of the small posts
Old Sep 29, 2011 | 07:54 PM
powerstroker100
by the way thanks for quick help I'm kind of freaking out because its starting to get cold here haha
Old Sep 29, 2011 | 07:58 PM
izzybird's Avatar
izzybird
GPR Operation
Old Sep 29, 2011 | 08:23 PM
powerstroker100
please disregard this thread and go to this one
https://www.ford-trucks.com/forums/1...l#post10867068
sorry for confusion
Old Apr 14, 2025 | 05:25 PM
Issame's Avatar
Issame
4wd Low
Test replacement ECM, can I test it without mounting it to the firewall?
When putting in a replacement ECM, can I test it without mounting it to the firewall?
Old Apr 15, 2025 | 03:14 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
In theory, yes, but in practice... the 104 pin wiring harness at the firewall isn't long enough to place and support the PCM anywhere else but where it is supposed to go.
I have run a PCM in this application unmounted, with the PCM laying on the floor where the center "20" seat or console would normally go, but to make that happen I had a 104 pin extension harness, in the form of a break out box.
The PCM has multiple ground pins, and is grounded through the 104 pin harness, even if the metal case of the PCM is not in contact with any metal spring tab on the mounting cradle screw.
knotreel
30
Aug 15, 2019 09:55 PM
knotreel
Aug 10, 2019 02:45 PM
Buck Dharma Fan
Jan 14, 2014 05:40 PM
awillo0406
Apr 3, 2013 10:42 AM
indyF-350psd
Jan 22, 2010 07:31 PM
