Sponsored by: Real Truck
removing the PCM
Old Feb 1, 2011 | 11:47 AM
mrwhite_350's Avatar
mrwhite_350
removing the PCM
i need to remove the pcm in my truck. am i going to have problems after plugging it back in? i heard sometimes the computer needs to reboot after this is done, which i expect, but i dont want any long term damage.
Old Feb 1, 2011 | 01:24 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Shouldn't be any problem just removing the PCM. SO long as the battery ground is disconnected and you reinstall the same one. The things controlled by it will "relearn" the different things after you have completed a number of drive cycles. Like correct idle, trans shift points etc.
Old Feb 1, 2011 | 01:30 PM
mrwhite_350
thanks; i'm not replacing it or anything, i just need to get some info off of it...so disconnect the ground wire before messing with the PCM...
Old Feb 1, 2011 | 03:05 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Look at this LINK. It will show you how to take the PCM out. I've taken my PCM out many times and never disconnected the ground cable.
Jmudweiser
Sep 13, 2016 05:02 PM
7.3 PowerStroke 350
Jul 2, 2013 08:21 AM
airboatoutlaw
1978 - 1996 Big Bronco
Mar 5, 2011 05:22 PM
dgpach
Modular V8 (4.6L, 5.4L)
Mar 2, 2010 07:04 PM
