PCM ground tab
Old Oct 3, 2016 | 02:42 PM
PNW350SD's Avatar
PNW350SD
PCM ground tab
I have read up on this subject and it seems my truck does not have this little tab in place.
Can you please clarify for me the purpose of this tab and what signs/symptoms I would see if the tab wasn't present/isnt replaced?
This is specific to my 2000 DRW 7.3 ZF6
Please advise.
Old Oct 3, 2016 | 04:28 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
In the pic below it is visible as the thin gold bit under the lower PCM bolt. The bottom arrow in the top pic points to it. It serves as a ground, but also to push the PCM against the firewall to maintain seal.
I found mine rolling around in the footwell a couple months after I installed the F5 chip. D'oh! I put it back in but evidently it is not critical. If the PCM does not ground I suppose you might see a hard/no start, maybe a P1316 code, etc.
Old Oct 4, 2016 | 03:24 PM
brian42's Avatar
brian42
Veteran: Navy
I may be wrong but I thought it was a PCM case ground to prevent electrostatic buildup (circuit boards don't like that too much). Much like wearing a grounding strap on your wrist when working on electronic components.
1Fastboy
Computer Chips & Tuners
Dec 21, 2020 10:52 PM
Riverboy460
Dec 31, 2013 11:22 PM
CREECY Strokin It!
Apr 5, 2011 03:28 PM
my93
Dec 23, 2010 03:40 PM
FreeDevin
Feb 6, 2010 07:50 PM
