Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
wiper motor
Old Nov 4, 2018 | 10:07 AM
Zrock's Avatar
Zrock
wiper motor
Looking for a wiper motor for a old 1995 Ford L9000 (i know it has a few more letters in their). Lat time i ordered it from ford they sent me the wrong motor. The motor on the dump truck was a long shaft and they sent me a short shaft. So i had to modify the output arm to make things work but the repair is starting to fail and need to find a new motor and arm. Found another dealer that supposibly had one to the tune of $400. From looking around a 95 f350 uses the same motor?
Old Nov 4, 2018 | 11:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Call: Auto Nation Ford in White Bear Lake MN for assistance. 800-328-9552 / 651-484-8888.
I don't have an L(ouisville) series truck parts catalog after 1994. The 1980/1994 L series motor is not the same as an F350. 1992/97 F150/350; F(Super Duty) & Bronco is different.
Old Nov 4, 2018 | 02:19 PM
Zrock's Avatar
Zrock
From my digging around Ford made 2 styles of motors for their 95 f350 and up series trucks. A long and short shaft electric. Would have probably had the proper one last time if the dealer would have ordered the one I told them to. But it was the middle of rain season and did not have the time to wait for the other to show. So I mofifyed the short shaft. I would definitely be interested in hearing your pricing as I have a few more things to order that the Canadian dealer I talked to cannot find. You can email me at islandrv@citywest.ca
Old Nov 4, 2018 | 03:08 PM
Destroked 450's Avatar
Destroked 450
The 95 model was still part of the 1st generation of Ford L series trucks, the 2nd generation design began in 96.
Parts for a 94 and earlier should work on a 95 model, when I replaced the wiper motor on my LTL9000 back in the late 90's my Ford truck dealer listed two, they gave me the wrong motor but the shaft length was the same on both, the wrong motor parked the arms in the up position
If ND can look one up for a 94 and earlier L series I'm sure it will fit your 95.
Old Nov 4, 2018 | 07:09 PM
NumberDummy
1990/2001 Ford Light Truck Parts Catalog:
F9PZ-17508-AA (replaced F5HZ-17508-A) .. Wiper Motor (Motorcraft MW-748). Also required: F9PZ-14A411-AA .. 5 Pin Wiring Connector.
1995/96 F150/350 & Bronco / 1997 F250 H/D & F350.
1973/79 & 1980/89 & 1990/94 Ford Heavy Truck Parts Catalogs:
F2HZ-17508-A (replaced D7HZ-17508-A & E9HZ-17508-A) .. Two Speed Wiper Motor (Motorcraft WM-447).
1978/94 L/LN/LNT/LT/LTL/LTS600/900 with electric wipers.
Old Nov 4, 2018 | 08:33 PM
Zrock's Avatar
Zrock
The heavy truck part numbers are not even close to the right one...
Old Nov 4, 2018 | 08:37 PM
NumberDummy
The numbers marked on the motors are ID engineering numbers, not part numbers.
No part numbers are marked on parts after 1956, just casting or ID engineering numbers, when applicable.
AFAIK, I'm the only member of FTE that has parts catalogs for 1990 and newer vehicles.
Previous year catalogs are available on C/D's scanned from original paper parts catalogs by hipoparts.com
But 1990 and later are on Ford microfiche slides, which means one needs a viewer to read them.
Old Nov 4, 2018 | 08:51 PM
Zrock's Avatar
Zrock
I was referring to the part numbers u just supplied. When I Google those numbers the parts showing up are not even close to what in the truck..
Old Nov 4, 2018 | 09:19 PM
NumberDummy
What part number does your truck use? I told you in post #2 that I do not have a parts catalog that covers 1995 and later Louisvilles.
The member in post #4 said 1995 is the same as 1994, that's why I spent 35 minutes researching and typing that jazz! (sigh).
Old Nov 4, 2018 | 09:26 PM
Zrock's Avatar
Zrock
Ahh I see now... sorry been a long day..
lol.. was out repairing the wipers again. Over tightened the bolt holding the arm on and of course it snapped off on the road...lol..
Old Nov 4, 2018 | 09:55 PM
Destroked 450
Bill
While searching through those numbers I found a old thread from this forum dated 2014, in that thread you stated that F2HZ-17508-A was replaced in 95 with F5HZ-17508-B
Here's a link to that thread
https://www.ford-trucks.com/forums/1...l#post14246898
Looked in PartsVoice and punched in D7HZ17508A, NOS Parts Source in Olathe, Ks has 1, Collectors Auto Supply 3 in Blaine, WA has 3
E9HZ17508A, none found
F2HZ17508A, NOS Parts Source has 1
F5HZ17508B, Marcotte Ford in Holyoke, MA has 1
Motorcraft WM447 doesn't show up
saauvenshine
Dec 26, 2014 11:13 AM
chadtexas
Aug 10, 2013 09:19 AM
DR Smith
Nov 27, 2007 03:51 PM
jawdoc
Mar 27, 2007 01:18 PM
cs6614
Apr 27, 2006 05:47 AM
