Zero ICP - no start
Old Nov 19, 2018 | 09:04 AM
  #46
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by timmyboy76
Made for the toolbag
That's what I'm talking about!
Originally Posted by andym
That's not going to solve this particular problem.
Oh, were those 3/8" drive sockets you've been looking at? Yeah those won't fit over the threaded portion of the IPR. You need a 1/2" drive (or better yet 3/4" drive) socket.
Old Nov 19, 2018 | 09:24 AM
  #47
PrescottIce's Avatar
PrescottIce
Originally Posted by PrescottIce
Not to derail the thread,
Whoops. Sorry.
Old Nov 19, 2018 | 09:40 AM
  #48
andym's Avatar
andym
No such thing as an 1 1/8" 3/8" drive socket. At least, not commonly. All the ones I was looking at are 1/2" drive. I also could not find a 3/4" drive socket that was as small as 1 1/8". IIRC the smallest 3/4" drive socket I found was 1 5/16".
My wonderful girlfriend took the socket down to the local Napa and they drilled out the center of the socket so it now clears the IPR.
I'll try to describe it: The bottom (the part that attaches to the ratchet) 1/4 of the socket is solid steel except for two holes. There is a square hole machined out of the solid part for the ratchet head, but that doesn't go all the way into the solid part. The rest of the solid part has a round hole drilled in it. That hole was too small to clear the IPR threads. Now that the socket hole has been enlarged, it fits over the IPR perfectly. The square part of the socket remains untouched.
At any rate, now I have a 1/2" drive IPR socket that cost me $21 to buy and modify.
Old Nov 19, 2018 | 02:12 PM
  #49
andym's Avatar
andym
No dice on the IPR change. I can get the socket on the IPR if I move the fuel line of the way by bending it a little, but I can't get the ratchet on the end of the socket. Not enough room. I can't fit the socket and ratchet in there as one because there's not enough room for that either.
None of the IPR specific tools get good reviews or work on the 7.3.
I will have to weld either a nut or a piece of flat stock on the back of the socket.
This has been an incredibly frustrating repair so far. Nothing has gone right at all.
Old Nov 19, 2018 | 02:32 PM
  #50
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Andy, this does not help you get the IPR out, but Diesel Tech Ron used one like this. A bit lower profile and swivel head on it.
Old Nov 19, 2018 | 02:53 PM
  #51
andym's Avatar
andym
That looks close to identical to the 1/2" ratchet that I have. I watched the video where he said "All you need to do is put an 1 1/8" socket on the IPR and take it out. I don't understand how it's that easy. I just spent 45 minutes busting my knuckles on it.
Old Nov 19, 2018 | 07:25 PM
  #52
F350-6's Avatar
F350-6
Try not bottoming the socket out on the IPR, or fully seating the ratchet into the socket. Put the socket on the IPR, pull it back a little, but where it still grabs, then place the tip of the ratchet in the socket. Don't fully seat the ratchet.
As long as the square part of the ratchet fits in the socket, you can loosen the IPR.
Old Nov 19, 2018 | 10:33 PM
  #53
timmyboy76's Avatar
timmyboy76
Are you sip'n on a cranberry juice or what, man...get at it or get off the pot.
Old Nov 20, 2018 | 07:31 AM
  #54
andym's Avatar
andym
I got the IPR changed yesterday. My large 1/2" ratchet simply would not fit. I forgot that I had bought this ratchet a few years ago and I was finally able to get it changed:
Amazon Amazon
Unfortunately, it made no difference. I still have zero ICP during cranking. Here's a cool graph, courtesy of forscan:
Next I'm going to change the ICP sensor. I have a new motorcraft one, I just need to get back down to the parts store to get an 1 1/16" socket.
Old Nov 20, 2018 | 07:52 AM
  #55
Wes444's Avatar
Wes444
Am i seeing 110 rpm? you said no start with icp unplugged right? Have you hooked up a manual guage to the hpop?
Old Nov 20, 2018 | 07:56 AM
  #56
Walleye Hunter's Avatar
Walleye Hunter
You know that you can unplug the ICP sensor and the system will default to a number that will let the truck run.(I think 1500 PSI)?
Old Nov 20, 2018 | 07:59 AM
  #57
andym's Avatar
andym
With the ICP unplugged, the PCM substituted a value of about 2,333 PSI. Still no start. I have not put an actual gauge on the HPOP rail yet although I'm getting closer to spending $80 on the tool to do it.
Old Nov 20, 2018 | 02:14 PM
  #58
andym's Avatar
andym
I replaced the ICP sensor today. The most immediate change is that now I'm getting plenty of oil to the injectors. Too much maybe?
Truck still won't start. Still won't buzz test.
Codes: P0676, P0683, (both glow plug codes) P1670. I get a P1668 when I try the buzz test.
I figured out how to get the ICP to display in PSI instead of kpa. Why is the ICP so high? I know my HPOP isn't putting out 3700 psi while cranking at 125 rpms.
Old Nov 20, 2018 | 02:49 PM
  #59
PrescottIce
I think I remember one of the start parameters being 200 RPM or more?
Doesn't explain your buzz test or the ICP pressure, but I don't know what would look normal on Forscan.
I monitor ICP via my head unit running Torque Pro, and the head unit goes blank when the key is in the start position.
Old Nov 20, 2018 | 02:55 PM
  #60
Walleye Hunter
No buzz...isn't that an indication that the IDM is not communicating with the injectors?
