when does it end ?
Old Oct 29, 2018 | 06:37 PM
Mark S Tomasi's Avatar
Mark S Tomasi
when does it end ?
2001 7.3 New reman, Everything on the engine is new ,everything Hard starts,smokes, shakes, no power, buzz test no codes, new valve cover gaskets and replaced pig tail connectors, thoroughly checked harness P1316,code New Idm 3 different cam sensors Grey and black,All new reman injectors,no corrosion at cannon plug or damaged pins ,Low temp on passengers side manifold, when warming up pulled electrical connecter on each injector while running and even across the board with rpm drop and recovery,Nothing I have done seems to fix the problem, been there done that ,
Old Oct 29, 2018 | 08:08 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Well the P1316 suggest either the IDM or the harness. I recently rebuilt my harness and it requires removing it, unwrapping it and visually inspecting 100% ever inch of wire.
turned up 3 of these, Seems to happen where a wire run branchs off the main trunk right under the turbo. Most likely from resting the turbo on the harness during removal.
Old Oct 29, 2018 | 08:10 PM
pirate4x4_camo
Sneaky little buggers...
Old Oct 29, 2018 | 10:13 PM
bigb56's Avatar
bigb56
good job, in the second pic it looks like the wire is chopped in half, is that right?
Old Oct 30, 2018 | 12:28 AM
pirate4x4_camo
Yup....classic intermittent short depending on how it was vibrating
Old Nov 1, 2018 | 04:06 PM
Mark S Tomasi
not over yet
Ok took the engine harness out and installed a new one form Ford, I did find one broken wire ,The black one in the center of the Passengers side valve cover plug, Since then , Still starts hard, blue smoke and ruff Idle Some improvement but not fixed, Buzz test # 3 fault P1273, High low, Contribution test same # 3 fault code P0269 What should I do next ?
Old Nov 1, 2018 | 04:26 PM
Silverhks's Avatar
Silverhks
How many miles is on the truck? Does the passenger side still not come up to temp as quick? Have you ever done any work on the fuel system?
I'm just spitballing here but the more info you provide the more we can help.
Old Nov 1, 2018 | 05:09 PM
Mark S Tomasi
The engine is new 1200 miles so far, New everything on the engine, Rebuilt turbo Fuel filter housing and all new injector pump, all new sensors.I had the injectors out and tested, switched 3 and 5 , still the same , Low temp on passengers side manifold,
Old Nov 1, 2018 | 06:15 PM
bigb56's Avatar
bigb56
What UVC gaskets did you use? A while back Dorman produced some faulty ones with two wires in the wrong terminals. Also some reported bad connections
Old Nov 1, 2018 | 06:39 PM
Mark S Tomasi
Valve cover gaskets are from ford.
pirate4x4_camo
Sep 22, 2018 01:07 AM
Sheryle
Sep 6, 2016 07:22 PM
lafermedavid
Mar 9, 2014 03:33 PM
pullinair
Mar 12, 2008 08:11 AM
