PCM Diagnostics Help Please
Old Oct 31, 2018 | 05:36 PM
BBslider001's Avatar
BBslider001
Ok, been doing a TON of research. I went out, started my truck this morning and it quit about 5 minutes into warm-up. It will crank, but no start. Here is what I know. Good #22 fuse, no OBD connection, no WTS light, no fuel pump operation, swapped relays and still no dice. Everything else Powers up except what is listed above. I ruled out everything from the flow chart. The flow chart leads me to PCM failure. He is dead in the water.
Anything I might be missing before I drop the heavy coin on another unit? Will any 7.3 manual SD PCM be ok, as in a 2000 even though I am early 99? A member has one for sale or I can send into the PCM repair guy, but I don't really have the time to be down right now. I did last week, but not this week FML.
Thanks again fellas. As always, great help here.
Old Oct 31, 2018 | 05:47 PM
Walleye Hunter's Avatar
Walleye Hunter
I thought that fuse #30 was the one that mattered here.
Old Oct 31, 2018 | 05:52 PM
BBslider001
It's relay and fuse 22 I think....unless the fuse is OBS 7.3 only. Either way, both are good.
Old Oct 31, 2018 | 05:54 PM
Walleye Hunter
OK, that covers that. I think (don't bank on it) that we can use up to an '01 PCM in our E99's
Old Oct 31, 2018 | 06:03 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Not all pCM “repair guys” are the same.... I learned the hard way and eventually ended up here.
https://www.dieseltechchatt.com/
nobody knows more about the 7.3 pcm then him.... he can repair what others can not.
Old Oct 31, 2018 | 06:04 PM
BBslider001
Ok...I am waiting to hear back or have someone verify. I have a line on a 2000 for a manual transmission. Hopefully I'll get verification. I don't have the $$$ to get one and then have to reflash as well....not today anyway LOL
Old Oct 31, 2018 | 06:05 PM
BBslider001
Thanks my friend. I'd send it to him in a second if I knew I could get it back pretty quick. I can't be down for a week. First world problems I guess. Does this sound like a PCM issue?
Old Oct 31, 2018 | 06:24 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Yeah pretty sure it's fuse 30 on a 1999. Remove wire from fuel bowl heater, replace fuse, do not replace wire.
Old Oct 31, 2018 | 06:30 PM
Colorado350's Avatar
Colorado350
Pretty sure it’s fuse 30 too. Byron, I have my E99 PCM if you need to borrow it. Let me know ASAP I’ll get it mailed out tomorrow morning.
Old Oct 31, 2018 | 07:52 PM
BBslider001
Fellas, John came through for an FTE brother in huge way. Rep him like crazy if you can. I'm in jail.
I'll recheck that fuse and fuel bowl heater wire when I get home. I'll report back.
FTE never fails to amaze me. It's just a great place.
Old Oct 31, 2018 | 08:07 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I am in rep jail too for John...
Byron, did you figure out what PCM's the ZF6 will accept? That may be good knowledge to share here on the forum if/when you do find out.
Old Oct 31, 2018 | 08:18 PM
Wes444's Avatar
Wes444
Im also in rep jail
I do personally know a Dac2/Dac3 will also work on a L99 ZF6
Old Oct 31, 2018 | 08:20 PM
Sous's Avatar
Sous
FTE Emeritus
I have a DPC-421 PCM in my truck best I can tell from my Hydra install records. Not really sure how that falls in line with an E99 or the DAC2/DAC3 that Wesley posted up though.
EDIT: The "box code" on mine is said to be XPC4, again not sure how this helps.
This is the image that I screen shot when I was installing my Hydra for future reference.
Old Oct 31, 2018 | 08:26 PM
Wes444's Avatar
Wes444
Sous
Old Oct 31, 2018 | 08:30 PM
Sous's Avatar
Sous
FTE Emeritus
Are you telling me that I failed to log the appropriate information/code for my pcm when it was out of the truck?
