I got my 2014 auto headlight hooked up and programmed, but the lights are on all the time in daylight. They go off with a delay after I remove the key. The lights stay on even in bright sunlight. What did I do or not do right?
I checked the codes again. Actually put them back as built and entered them again. This time I have 3 DTC codes. RCM:B00D5:13-08 SCM:B10A6:09-08. IPC: U0422:56-0A and lights still function as I said above.
If the codes are correct, then I would look at the wiring again and make sure you connected everything to the correct spot.
