Morimoto SB LED Headlights
Old Oct 19, 2018 | 04:46 PM
LaxPlaya21's Avatar
LaxPlaya21
Originally Posted by CO Wapiti
I did read that section carefully. Even OEM lights are not legal if they are aimed improperly so I don’t see what’s so tricky about that statement.
It always kills me on this forum when other folks are excited about getting a new accessory for their SD and others chim in about how stupid it is to spend money on that item. I figure everyone will spend their money how they see fit. My business is paying for these so after tax savings they’re really only going to net out at around $1000 for me. I happen to be excited about these lights and they will be aimed properly to meet any regulations because I care about what oncoming traffic is seeing.
To those of you who say the OEM lights are only a $!080 upgrade, well, I have an XLT value package so I saved a ton of money over the higher trim packages BUT the one thing I wanted was the LED lights for my failing eye sight and I couldn’t piece meal these like some other options. Others have added the OEM lights for around $2000 after their truck purchase and with much labor and trouble along the way. I am excited to spend the money I am spending on something that actually throws a better light pattern than OEM. They have a 5 year warrantee which is comparable to factory as well.
Please report back when you install these lights with a detailed review if you can. I think they look pretty slick and they are bound to be excellent performers. I never understand how people think spending money on quality lighting is ridiculous. Yet they throw money at intakes, tuners, brakes and everything else. You can spend all the money you want on brakes, but without quality light to see what is in your way you won't have a chance to use them!
Old Oct 19, 2018 | 05:56 PM
sfdvisuals's Avatar
sfdvisuals
i have used morimoto before and can say some of the best customer service I have had in quite some time was from the retrofit source. doesn't help much with these headlights, but did great for my Acura.
Old Dec 13, 2018 | 02:32 PM
amorrow02's Avatar
amorrow02
I see the date has been pushed back a few times on these. Does anyone know whether later this month is an accurate time to expect these to be available?
Old Dec 13, 2018 | 02:41 PM
MNSuper's Avatar
MNSuper
I just emailed them a couple days ago and got this response
Thanks for the email! We're thankfully still expecting them before the end of this year. Being a pre-order it's possible they could come in sooner/later than expected but we always do our best projecting ETA's on them.
Once in hand we'll fill all the pre-orders and email you tracking so you have a better ETA to your door.
Have a great week and thanks again,
Charlie
Old Dec 13, 2018 | 02:52 PM
amorrow02's Avatar
amorrow02
Thanks for the info!
Old Dec 13, 2018 | 04:25 PM
pepatrick01's Avatar
pepatrick01
I ordered mine back on November 5th. They told me back then it would probably be late December.
Old Dec 14, 2018 | 10:44 AM
Gazoo2010's Avatar
Gazoo2010
Are they plug and play or do you need to change the harness or re-wire?
~S
Old Dec 14, 2018 | 03:51 PM
pepatrick01
I have downloaded and read the installation directions. They are plug and play. One wire has to be run to the fuse box for DRL but I think I will do something a little cleaner. I had actually purchased the OEM LEDs and was going to rewire them (as I did on my 2016 F-150) when I owned it. The Morimotos look pretty cool and a different look. Im 53 but that still doesn't mean I have to grow up. LOL
Old Jan 7, 2019 | 01:55 PM
amorrow02's Avatar
amorrow02
Looks like delivery of these are now pushed back to late February/early March with option to expedite for late January delivery for extra $150. Anyone else pre-order and get this notification?
Old Jan 7, 2019 | 02:15 PM
pepatrick01
I got the same message today from TRS.
Old Jan 7, 2019 | 02:21 PM
JetMechJoe's Avatar
JetMechJoe
so you order way in advance....they give you a date range on when to expect them, then they push that date out by double but ask you to pay more to get them a month or so sooner which is later then their original estimated ship date? that right there is a big turn off in dealing with them as a company based off of ethics/principles. Has anyone received a set and if yes, can we see photos? thanks
Old Jan 7, 2019 | 05:00 PM
honda250xtitan's Avatar
honda250xtitan
they shipped a set out the other day finally.
Old Jan 7, 2019 | 05:04 PM
  #28
CO Wapiti's Avatar
CO Wapiti
I received the notice as well. First off, I knew there was no way we would be getting these in December as promised. Fullfilment dates are rarely reached for most new products. Second, there's no way I'm giving an extra $150. I'll just wait for them.
On another note....has anyone ever removed the factory light assemblies yet? How far forward do they have to be pulled forward for them to release? I have an aftermarket bumper and winch and I only have about 3/4 of an inch clearance at the bottom of the headlight assembly to the pre runner bar of my bumper. I sure hope I won't have to remove that bumper to get these new lights installed.. With the winch I'm sure it's about 450 lbs.
Old Jan 7, 2019 | 05:10 PM
  #29
ATC_F350's Avatar
ATC_F350
The own leds are a $5g upgrade from the base Lariat. You have to add the Lariat Ultimate, the leds and the Blis is forced on too.
Old Jan 7, 2019 | 07:31 PM
  #30
RAY1969's Avatar
RAY1969
I just replaced the stock fog light bulbs with LEDs in my 2019 SD and they are about as bright as the low beams now but with a wider spread. Based on that I've ordered the LED bulbs to replace the low beams. The owner of the shop has had a set in his SuperDuty for three years with no issues. For only $300 compared to $2K, they're worth a try as far as I'm concerned.
