Tire size for leveling kit
Old Sep 27, 2018 | 12:43 PM
stangDiesel's Avatar
stangDiesel
I got a 18 F-250 Platinum, with a ready lift 2.5 leveling kit. I want to run all-terrain hybrid tires. I have some 35/12.5/24 mud tires at the moment and I want to stay level for now. I had to do slight trimming on the inner fender with my current set up. Tthat being said, can I fit a 36 inch tire if I do more trimming or do I need to go to a 33 inch tire? How much would that effect ride quality with the smaller tire?
thanks.
Old Sep 27, 2018 | 12:52 PM
Tricon's Avatar
Tricon
Its gonna ride like crap, but I can't imagine it rides well with those rubber bands you have now anyways?
Tire size isn't an issue, 35x12.50 should fit without any rubbing on a stock truck, I'm guessing you have a ridiculously wide rim with a large negative offset though, its the rims and the offset thats getting you. What width is your rim and what offset or backspacing are they?
Old Sep 27, 2018 | 02:36 PM
stangDiesel
It's the Fuel Forged ff02 2x12 -44 offset. It was a slight trim. The thing I'm not fond of is the noise the tires make. I put on my stock rims with the Nitto Trail Grapplers and it is quite as heck. I want to put some Nitto tires over the cheap Chinese wheels I went with.
Old Sep 27, 2018 | 02:41 PM
Tricon's Avatar
Tricon
Yea, those are sticking way out there. I couldn't tell you, I only really have a lot of personal experience in the 0 offset or less. Pretty easy to tell though, crank your steering wheel to lock and pull into a driveway, or up on a curb. See how close you are to rubbing, then add .5" to that and you'll see where a 36" tire would be.
But....you'll be hard pressed to find a 36" AT tire. I think most of them are going to be Thornbirds or IROKs, exactly the type of tire you dont want. Most ATs will be 35 or 37, I think theres a metric size in there that might be a 35.2, but most metric sizes top out at 35.
Old Sep 27, 2018 | 04:24 PM
stangDiesel
how about the Atturo?
AtturoTrail Blade X/T
[***************]GOOD
LT325 /45 R24 120S E2 BSW
Specifications
  • Size
  • Wheel Diameter 24
  • Aspect Ratio 45
  • Section Width (Cross Section)325
  • Overall Diameter 36
  • Rim Width Range 10.0-12.5
  • Rim Width
  • Weight59
Old Sep 27, 2018 | 04:38 PM
stangDiesel
but I will try that trick you mentioned
Old Sep 27, 2018 | 04:44 PM
stangDiesel
NittoRidge Grappler
[***************]BETTER[/color]
LT315 /50 R24 127Q F2 BSW
Wheel Diameter24
  • Aspect Ratio50
  • Section Width (Cross Section)315
  • Overall Diameter36
  • Rim Width Range8.5-11.5
  • Rim Width
  • Weight85
Old Sep 27, 2018 | 05:51 PM
Tricon's Avatar
Tricon
Those Nittos are too skinny for your wheels, it would work, but your rim lip would be sticking out there. I dont have much experience with Atturo, they seem like a cheap Korean brand to me, but I couldnt say one way or the other. I think the Nitto or a Toyo would be best ultimately, not sure if they make a size for you though.
96sherm
2004 - 2008 F150
29
Dec 23, 2012 11:49 AM
Gwilkrrs
6.4L Power Stroke Diesel
Aug 10, 2011 05:34 PM
M Green
2004 - 2008 F150
Jan 5, 2010 01:54 PM
Stevie Ray
May 22, 2009 03:59 PM
judithgap
2004 - 2008 F150
Apr 17, 2005 05:42 PM
