inline fuel pump
Old Sep 26, 2018 | 06:23 PM
Megathomas's Avatar
Megathomas
Exclamation inline fuel pump
I got two questions, the first one is what is the size of the fuel lines on a 1995 ford f-350 with a 351W? And the second is can an inline fuel pump work with the truck and what PSI and GPH should I get?
Old Sep 26, 2018 | 10:06 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
The lines are likely 5/16" or 3/8" inner diameter. Take one off the truck and measure it. Have not seen/heard of an inline/external pump that could run a EFI vehicle, those are usually low pressure pumps designed for carbureated vehicles. Use the OEM in tank style to achieve the needed 30-50 PSI and flow rate.
Old Sep 26, 2018 | 10:20 PM
Megathomas's Avatar
Megathomas
Originally Posted by Da_Lariat_Chariot
The lines are likely 5/16" or 3/8" inner diameter. Take one off the truck and measure it. Have not seen/heard of an inline/external pump that could run an EFI vehicle, those are usually low-pressure pumps designed for carbureted vehicles. Use the OEM in tank style to achieve the needed 30-50 PSI and flow rate.
well, I found an inline fuel pump online that could handle EFI. Here is the link:
Amazon Amazon
Old Sep 26, 2018 | 10:32 PM
westcoasting's Avatar
westcoasting
well, I found an inline fuel pump online that could handle EFI. Here is the link: https://www.amazon.com/dp/B0797SZ7NC...ing=UTF8&psc=1
Just junk! Go with the stock motocraft pump.
Old Sep 27, 2018 | 07:47 AM
subford's Avatar
subford
That is the type pump used for the 1990 and older fuel injector trucks. You can get the same type fuel pump from any auto part store if you ask for the frame mounted HP pump for a 1990 Fuel injected F-series truck with a 300, 302, 351 or 460 engine.
Are you changing to different fuel tank?
The in tank pumps for your truck puts out more than enough fuel and pressure for your engine.
Old Sep 27, 2018 | 09:34 AM
Megathomas's Avatar
Megathomas
Originally Posted by subford
That is the type of pump used for the 1990 and older fuel injector trucks. You can get the same type fuel pump from any auto part store if you ask for the frame mounted HP pump for a 1990 Fuel injected F-series truck with a 300, 302, 351 or 460 engine.
Are you changing to the different fuel tank?
The in-tank pumps for your truck put out more than enough fuel and pressure for your engine.
the reason why I want to change my fuel pump from an in-tank pump to a mounted one is that it's cheaper and easier to change
and I'm not changing to a different fuel tank.
Old Sep 27, 2018 | 10:26 AM
subford's Avatar
subford
Do you have two fuel tanks?
If so how are you going switch tanks?
If the in tanks pumps are dead or not there and you run out of fuel the frame pump may not reestablish prime and the engine will not restart.
Are you removing the in tank pumps?
Old Sep 27, 2018 | 08:24 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
This one might work, 45-65 PSI and 35 GPH.
https://www.oreillyauto.com/detail/b...q=e16098&pos=0
benderbus
Dec 1, 2016 11:59 PM
312
Apr 19, 2011 06:50 PM
kenneBF250V10
Modular V10 (6.8l)
29
Apr 28, 2006 10:36 AM
javi2001
Jul 25, 2003 11:49 AM
jwtaylor
Oct 30, 2001 11:22 AM
