Voltage drops when running lots of accessories - Ford Truck Enthusiasts Forums
Old 09-20-2018, 10:50 AM
johnnyfoodstamp
johnnyfoodstamp is offline
johnnyfoodstamp is starting off with a positive reputation.
89 F150 lariat xlt here. I recently fixed the ac/heat and I've noticed at night if I have the headlights on, the ac, and maybe a blinker or windshield wipers or whatever the voltage will drop significantly and the truck will even die at a red light or whatever unless I give it some gas. I'm thinking maybe I need a better battery but I thought I would throw it out to the hive mind and maybe there's another reason for the voltage drop. Thanks ya'll.
Old 09-20-2018, 10:57 AM
seville009
seville009 is offline
seville009 is gaining momentum as a positive member of FTE.seville009 is gaining momentum as a positive member of FTE.
Check the battery voltage - should be 12.5 or 12.6 off. If it is, the battery should be good.
Then turn the engine on and test the battery agsin when itís running. Should be at least 14. If itís under that, your alternator might not be working right.
Old 09-20-2018, 11:03 AM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Keep in mind the factory 2G alternator puts out very little to no power at idle/low RPMs. That's a design flaw. Highly suggest you upgrade to a 3G to fix your current issue and prevent the flamethrower 2G from claiming another victim.
Old 09-20-2018, 11:17 AM
johnnyfoodstamp
So I just checked the battery with a voltmeter and I got 12.6 and when I start the truck I've got 14+ so I don't think it's the battery. Must be the 2G alternator. I'm looking on Napa's website now and I don't see them labeled as 2g or 3g so I'll give them a call and figure it out. Thanks ya'll.
Napa alternators
Old 09-20-2018, 11:23 AM
rla2005's Avatar
rla2005
rla2005 is offline
The factory replacement alternators listed for your truck are all 2G design. Everything you wanted to know about the 3G upgrade: https://www.fullsizebronco.com/forum...ins-agian.html
Old 09-20-2018, 11:27 AM
johnnyfoodstamp
That's very helpful. So I see mine is only capable of 75 amps and the 3g is upwards of 100-150. So that link tell's me everything I need to know except where to buy one.
Old 09-20-2018, 11:32 AM
johnnyfoodstamp
Old 09-20-2018, 11:37 AM
rla2005's Avatar
rla2005
rla2005 is offline
Order an alternator for one of these:
(1994-95) Ford Mustang 5.0L
(1994-00) Ford Mustang 3.8L
(1994-97) Ford Thunderbird, Mercury Cougar 3.8L
(1990-95) Ford Taurus, Mercury Sable 3.8L
(1993-99) Ford Taurus, Mercury Sable 3.0L
(1995-98) Ford Windstar 3.8L & 3.0L
(1991-94) Lincoln Continental 3.8L
Old 09-20-2018, 01:21 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Da_Lariat_Chariot is offline
Da_Lariat_Chariot is gaining momentum as a positive member of FTE.
Do the 3G upgrade, totally worth it. Installed a 95 mustang v6 alternator rated at 130 amps. You gotta use an angle grinder to cut the bracket slightly to make it fit and fabricate wiring but it's not that bad. I was very impressed with the results.
Old 09-20-2018, 07:46 PM
whisler
whisler is offline
whisler is gaining momentum as a positive member of FTE.whisler is gaining momentum as a positive member of FTE.
I did exactly as above and all works great.
Old 09-21-2018, 06:54 AM
johnnyfoodstamp
95 Mustang alternator is $168.00 at Napa.... yikes Napa Any way to field test an alternator at the junkyard? I wouldn't generally buy a junkyard alternator but in this case....
Old 09-21-2018, 08:05 AM
whisler
whisler is offline
I bought mine from a guy who was replacing the V-6 with a V-8 to build a race car. I think I paid $30.
Old 09-21-2018, 11:51 AM
johnnyfoodstamp
I'll give you $35 for it.
Old 09-21-2018, 03:40 PM
puppyf250
puppyf250 is offline
puppyf250 is starting off with a positive reputation.
Soooo, when did they start putting 3G in F-250? I currently have a 91, that I am rebuilding, wondering about this upgrade.
Old 09-22-2018, 10:27 AM
Da_Lariat_Chariot
Late 90s I think.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
