7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Gasoline powered 7.3 engine...
Old Sep 14, 2018 | 05:55 PM
akcooper9's Avatar
akcooper9
I agree with you sous. I didnt buy the tank so I could go a long ways with out stopping, I bought it so I could buy when I wanted and where I want.
I hold a total of 95 gallons and on our last trip from TX to GA, we saw diesel prices for 2.60 to 3.30. I believe our avg purchase price was 2.80 over a 2000 mile trip.
Mine is also on a switch with a pump. We set a timer for 20 minutes per pump so I dont forget to leave it on....
Old Sep 14, 2018 | 06:15 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
As I have said before, mine is on a momentary switch and I usually will move fuel from the auxiliary tank to the main tank for about 5 miles at 65 MPH. That gives me about 1/4 tank of fuel back in the main tank. Having 1000 mile range with the camper attached is very nice indeed.
Back on the topic of the off topic thread...
The 6.2 is said to get 13-15 MPG's unloaded, so if the 7.3 gasoline engine does better than that, it would be up near the diesel 6.7 MPG's. Not sure what the 6.2 gets towing ~10K lbs though...
Old Sep 15, 2018 | 02:18 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by SRBF150
. Neighbor has a 2017 f250.... $1050/month... no thanks. .
Originally Posted by Sous
That is more than my mortgage!
Originally Posted by Fat Diesel
C'mon out to CA and we'll set you up with a real mortgage. I'm pretty sure I pay the equivalent of a small African nation's GDP each month.
Yup. That $1000 a month in payments won't even get you a nice one bedroom apartment here on the Central Coast.
Stewart
Old Sep 17, 2018 | 01:42 PM
Josh Ross's Avatar
Josh Ross
Diverdude
Are there any write-ups on adding that second fuel tank to pump while driving in to the main tank? That sounds like a worthy investment for my future towing of a 5'er!
Old Sep 17, 2018 | 02:06 PM
Sous's Avatar
Sous
FTE Emeritus
I installed my tank back before I was doing write-ups and videos. Although, I did document the procedure fairly well in the thread below.
https://www.ford-trucks.com/forums/1...ne-almost.html
I also have the instructions from the company I bought the tank and parts from if you want me to send them to you shoot me a PM with your email address and I will send them over.
You are right, it is a very worthy investment and one of my favorites. Nearly 1000 miles of range with the camper in tow, nearly 1500 miles of range without the camper in tow. Stop when and where you want, instead of when you have to. We have drive cross country many times and the tank has paid for itself many times in ease of filling and choice of stops.
Old Sep 18, 2018 | 08:24 AM
Tugly's Avatar
Tugly
I used to have an engine similar to that - it was called a 460. Can you say "fuel hog"?
Old Sep 18, 2018 | 09:51 AM
Sous's Avatar
Sous
FTE Emeritus
Yes sir! I think this is where the enthusiasts are upset because they feel that the 7.5L (460cui) should have been the new gasoline engine instead of a 7.3L.
I will be interested to see what the new technologies and advancements bring to an engine of this size and the intended purposes, but still think they should not be using the 7.3L size.
Old Sep 18, 2018 | 12:04 PM
Fat Diesel's Avatar
Fat Diesel
There will be very little to compare between a fifty year old design like the 460 and the new all aluminum 32 valve monster that will be forthcoming. For reference, compare the 225 HP 5.0 of 1993 to the 475 HP 5.0 of the new Bullitt.
Old Sep 18, 2018 | 12:09 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
440 hp, 510 ft lbs?
Old Sep 18, 2018 | 12:16 PM
liquidlounge's Avatar
liquidlounge
I HIGHLY doubt it will be 32 valves being that it is a pushrod design.
Old Sep 18, 2018 | 01:01 PM
KubotaOrange76
oh its confirmed to be push rod? Awesome
I wouldn't put it past ford though, look at their 6.7 they designed in house. Pushrod 32V
Old Sep 18, 2018 | 01:24 PM
z31freakify's Avatar
z31freakify
Its not confirm that its going to be push rod or OHC. Some guy in the SVT forum claim it was a push rod design but who knows. If Ford desides to go push rod, its a backwards step, but I hope its a pushrod design simple and efficient.
Old Sep 18, 2018 | 01:27 PM
  #28
liquidlounge
From what I read, the pushrod design was chosen to make for the smallest, lightest package possible. 16 valves vs. 32 valves makes for a significantly narrower when you consider that the little extra width required for the 4 valve is expanded because of the twin bank, V configuration. My bet is 16 valves. Look at the GM LS motors; tiny envelope and very light for their power output...and really, the 2 valve, pushrod design is still pretty competitive as a truck motor; i.e. GM and RAM.
Old Sep 18, 2018 | 03:48 PM
  #29
KubotaOrange76
knowing ford it will be a 40v with two miles of special custom designed low noise timing chains and they will be on the back of the engine driving 6 cam shafts
Old Sep 19, 2018 | 09:10 AM
  #30
Fat Diesel's Avatar
Fat Diesel
I HIGHLY doubt it will be an archaic pushrod engine. It's been what, eight years since Ford has come up with a pushrod engine?
