226 Throttle Spring
Old Sep 7, 2018 | 07:51 PM
ct50f1's Avatar
ct50f1
226 Throttle Spring
I've put the throttle spring back on my carburetor the same way that it was set up when I bought the truck but I'm not sure if it's correct. It seems strange that Ford would have attached it to the cotter pin. Does anyone have there's set up differently or is this the way it was originally done?
Old Sep 7, 2018 | 08:05 PM
3twinridges's Avatar
3twinridges
There is a hole in the floor pan on the passenger side where a cotter pin goes. The mat hides it. The return spring attaches to that and the arm on the linkage.
JB
Old Sep 7, 2018 | 08:12 PM
ct50f1's Avatar
ct50f1
JB
Thanks for the description. Does anyone have a picture of that setup?
Old Sep 7, 2018 | 10:29 PM
51fred's Avatar
51fred
Here is mine. You can see the head of the cotter pin to the left.
Old Sep 8, 2018 | 12:57 AM
52 Merc's Avatar
52 Merc
As noted by the others, the cotter pin spring attachment is factory. Believe it or not. Fred's pic is absolutely correct.
Old Sep 8, 2018 | 06:46 AM
Marauder2004's Avatar
Marauder2004
This is a timely thread- I just found that spring in my shop yesterday and now I see where I should use it!
Old Sep 8, 2018 | 07:10 AM
ct50f1's Avatar
ct50f1
Thanks Rich and Wayne, very helpful.
Old Sep 8, 2018 | 10:51 AM
ct50f1's Avatar
ct50f1
I just measured my spring and it's only 5 1/2" long but the distance from the firewall to the arm on the linkage is about 9". I guess I have the wrong spring. I don't have anything else I need right now so it's not worth ordering just the spring. Will probably leave it the way it is for now since it seems to work.
Old Sep 8, 2018 | 11:32 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The hardware stores have a good assortment of universal springs. I lost my clutch pedal spring and found a nearly identical spring there for $2.
Old Aug 7, 2024 | 11:57 AM
grgrywils's Avatar
grgrywils
2nd Gear
me Too 226 Throttle Spring
I too seem to have the same set up in my 50 Ford Custom but I have no spring. do you have the size? and or where do I get one. thanks Greg
Old Aug 7, 2024 | 09:19 PM
52 Merc's Avatar
52 Merc
Is your 50 Ford Custom a car or a truck? If it's a car, the folks here on a truck forum may not have a good or correct answer for you. I have a lot of truck books and catalogs, but nothing to help with car parts.
Old Aug 8, 2024 | 06:54 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
The only readily available spring offering for the 1950 226 Ford Custom is the "universal fit" C7AZ-9737-C which is not an improvement as you custom fit it...
Old Aug 14, 2024 | 10:28 AM
bmoran4's Avatar
bmoran4
@grgrywils , I may have been on the wrong trail above... Are you looking for the spring on the 9725 assembly?
If so, the whole assembly is 8HA-9725-A and possibly could be found on the used but serviceable secondhand market:
https://www.ebay.com/itm/124575374001
dstraw
16
Sep 2, 2024 01:59 PM
3twinridges
Nov 16, 2020 06:55 PM
Dag L
May 31, 2011 05:03 AM
pdqford
Apr 5, 2009 12:57 PM
Christopher2
19
Jan 15, 2005 10:04 PM
