Throttle/kickdown springs
Old Jul 15, 2014 | 01:12 PM
dstraw's Avatar
dstraw
Do I have these in the right position?
Old Jul 15, 2014 | 05:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
43 views and no one has said "let me go look under my hood", wow. I am long way from my trucks and will give it a guess, like a faint memory check.
As far as your question, NO the front one should be connected to the same place the rear one is on the carb linkage.
And the rear spring should be straight off the back, to a tab that is in the lower right corner of your pic. It is a small lone metal tab held down with a intake manifold bolt, I do believe??
You can double the springs (a smaller one inside a bigger one) to get the pedal stiffness you like. Meaning with the gas on and then a quicker shut off too.
Some off road and mud bog folks do it to make the pedal not so bouncy with the drivers foot.
Old Jul 15, 2014 | 05:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0
From looking at the illustration in the parts catalog, it looks like the spring at the back is correct. The front spring however isn't right. It's connected to the engine correctly but according to the illustration, it doesn't hook to the kickdown arm.
In the illustration it looks like there is another hole on the same arm as the rear spring is hooked to. It is just below the ball joint that the accelerator linkage connects to. It looks like it would be obscured by the linkage in the picture you posted.
Old Jul 15, 2014 | 06:33 PM
HIO Silver's Avatar
HIO Silver
What would be the "correct" configuration for a 76 FE with a manual trans? Is the linkage spring on top of the linkage and mounted to a bracket under the coil stud or mounted under the linkage and the spring clipped to a bracket on the manifold?
The reason I'm asking is that I deleted the funky "trapeze" linkages/brackets and can go with either way.
Old Jul 15, 2014 | 06:53 PM
74F0NE's Avatar
74F0NE
this is a 302
Old Jul 15, 2014 | 08:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
HIO, according to the illustration in the parts catalog, a '76 FE uses the same basic set up that 74FONE shows in the pictures of his 302.
Old Jul 16, 2014 | 07:49 AM
dstraw's Avatar
dstraw
Thanks! The pictures are incredibly helpful.
Old Jul 16, 2014 | 08:39 AM
460me's Avatar
460me
This is with a Lokar kick down cable:
Old Apr 12, 2016 | 02:48 PM
grandpas1974's Avatar
grandpas1974
Bumping this one since 74ONE has excellent pics of my exact setup. My question is regarding the yellow kickdown lever in the pics. Mine has a lot of side to side "slop", it moves easily side to side. I actually have to hold it out of the way to adjust the curb idle screw on the carb. Is it supposed to be this loose???
Old Apr 12, 2016 | 02:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The kickdown does have a lot of side to side slop in it. One thing, check the little plastic bushing that's in the throttle end of the kickdown rod. Sometimes they break up and fall out making the linkage's fit even sloppier.
If the bushing is gone, the entire rod needs to be replaced, Ford never sold the bushings separately.
Old Apr 12, 2016 | 03:11 PM
grandpas1974
Thanks! Will do.
Old Sep 23, 2016 | 07:06 AM
Damifiknow's Avatar
Damifiknow
Anybody have a pic with rod installed on a Edelbrock 600 CFM? When I changed carb the rod wasnt hooked up. I think I need #1483 kit but not sure. Any pic of rod connected and how to adjust would be great.
Old Sep 23, 2016 | 01:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Lower pic:
Old Sep 26, 2016 | 10:20 PM
tbear853's Avatar
tbear853
If you meant kick down rod .... I made the extension piece years ago, adjust the kick down so that it's all the way back at wide open throttle.
The red spring is pulling the kick down forwards until the screw tip hits the tab and the kickdown lever is moved rearwards.
The blue spring returns the throttle to closed.
Old Sep 27, 2016 | 07:40 AM
Damifiknow's Avatar
Damifiknow
I used the kit Edelbrock sells for 30 bucks and the kick down rod attached exactly where it needed to make it work. Adjusted screw so it engages at WOT and viola its works great. No extension of rod needed.
