Drivers Side Negative Battery Cable Routing
Old Aug 25, 2018 | 12:02 PM
richlars's Avatar
richlars
Every time I start a project I swear I am going to take lots of pictures, but always fail. So I am putting everything back together after installing a bunch of cooling goodies and I can't remember how the drivers side negative battery cable is routed and where is lands. any help would be appreciated,
Rich
Old Aug 27, 2018 | 07:12 PM
Walleye Hunter's Avatar
Walleye Hunter
It lands on a bolt on the front of the block somewhere near the head IIRC. It should be easy to see the spot for the bolt or the stud sticking straight out the front of the block.
Old Aug 27, 2018 | 08:40 PM
RigCity's Avatar
RigCity
There is a photo of the drivers side ground
Old Aug 27, 2018 | 10:25 PM
Firefighter 1406's Avatar
Firefighter 1406
Driverside is just a bolt on mine. Passenger side is a stud on my truck, which also holds the battery cable going back to the starter.
Make sure and put a star washer behind the cable. Get a nice bite for the ground.
Old Aug 28, 2018 | 02:35 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Use points of reference, like the square key socket plug, for orientation and location.
Old Aug 28, 2018 | 03:04 PM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
It routes going down the side of the battery and then to the top of the frame rail, then across to the front of the motor where the bolt goes to ground it. Just changed out all my battery cables and that's how the stock ground on the driver side was ran on my 01.
Old Aug 29, 2018 | 10:14 PM
richlars's Avatar
richlars
Thank you all very much. Found it and is all grounded now, Great pictures!
High_HP
Oct 30, 2018 06:01 PM
willowbilly3
Jul 27, 2016 04:47 PM
VaFordman26
Apr 4, 2013 10:46 AM
adworden
Sep 28, 2012 11:10 PM
slntnddly
Dec 22, 2003 06:40 PM
