Add Water Temp Gauge?
Old Aug 22, 2018 | 05:12 AM
JWA's Avatar
JWA
About to add an Auto Meter GS-Series water temp gauge, curious where to place the sending unit? I can add one of the upper/lower radiator adapters, have seen t'stat housings with a port and there's an existing port in the hot coolant crossover at the engine front.
Any ideas or experience installing of these, where can I stick it?
TIA
Old Nov 30, 2018 | 11:03 AM
simplebuck's Avatar
simplebuck
I've also been wanting to install a coolant temperature gauge, only a mechanical one.
Still need a good place to install the sensor bulb.
I've considered making an inline piece with a threaded connector, and installing it into the heater hose that supplies the heater core.
I don't see any other place to put it.
Old Dec 1, 2018 | 04:43 AM
JWA's Avatar
JWA
On my 2005 E350 with 5.4 engine I found a port in the coolant crossover passage at the front of the intake. The Auto Meter sending unit threaded right in, working fine now.
Old Dec 1, 2018 | 10:34 AM
alloro's Avatar
alloro
They make the adapters you need, here's an example.
MMWHS-32-BK - Mishimoto Water Temp Sensor Adapter - throtl - New Performance Parts at the Best Prices
Old Dec 2, 2018 | 09:59 AM
simplebuck's Avatar
simplebuck
thanks, alloro,
That looks pretty good .... looks like it's intended to fit inline into the upper radiator hose.
Old Dec 3, 2018 | 04:31 AM
JWA's Avatar
JWA
Originally Posted by alloro
I had one of those, it worked fine but opted for the already-existing port. Mine was from Glow-Shift, decent quality but super cheap and suspect screw drive clamps included---I used a better grade for peace of mind.
Old Dec 3, 2018 | 09:48 AM
alloro's Avatar
alloro
I agree, if you have a threaded port in a coolant jacket you should definitely use it. But for those that don't, the in-line hose adapter is a great solution.
Old Dec 14, 2018 | 06:51 PM
jerryparks's Avatar
jerryparks
My 05 F150 does not have that threaded port. From my understanding the modular engines circulate coolant to the heater core full time, where the upper rad hose only circulates when the thermostat is open. So if that's true, would it be better to mount the sending unit in the heater hose to get a more accurate read?
Is there another port I can mount the sending unit into?
Old Dec 15, 2018 | 04:44 AM
JWA's Avatar
JWA
True that the Modular Motors circulate coolant all the time through the heater core and upper radiator hose only when t'stat opens. I don't know there's a better place to monitor coolant temperature--since I'm running an after market temperature gauge I prefer seeing it rise slowly rather than just pop up to temperature all at once. The instrument cluster gauge seems to do this same thing but there's no numbers associated with the pointer location which is one reason I added the other gauge.
Most are happy with using the radiator hose adapter shown earlier if there's no other port to access. BTW for a short while I used the Glow Shift adapter, cost about $20 through Amazon IIRC.
HTH
bigb56
Aug 1, 2015 06:21 PM
lhud
Computer Chips & Tuners
Oct 8, 2012 03:45 PM
KenS999
Mar 17, 2008 03:58 PM
fourbyfourman
1997 - 2003 F150
Jul 8, 2007 05:48 PM
MustangGT221
Apr 12, 2005 06:26 PM
