Add Water Temp Gauge?
Old 08-22-2018, 05:12 AM
JWA's Avatar
JWA
JWA is offline
Received 1,417 Likes on 1,117 Posts
About to add an Auto Meter GS-Series water temp gauge, curious where to place the sending unit? I can add one of the upper/lower radiator adapters, have seen t'stat housings with a port and there's an existing port in the hot coolant crossover at the engine front.
Any ideas or experience installing of these, where can I stick it?
TIA
Old 11-30-2018, 11:03 AM
simplebuck's Avatar
simplebuck
simplebuck is offline
I've also been wanting to install a coolant temperature gauge, only a mechanical one.
Still need a good place to install the sensor bulb.
I've considered making an inline piece with a threaded connector, and installing it into the heater hose that supplies the heater core.
I don't see any other place to put it.
Old 12-01-2018, 04:43 AM
JWA's Avatar
JWA
JWA is offline
On my 2005 E350 with 5.4 engine I found a port in the coolant crossover passage at the front of the intake. The Auto Meter sending unit threaded right in, working fine now.
Old 12-01-2018, 10:34 AM
alloro's Avatar
alloro
alloro is offline
Received 4,242 Likes on 2,473 Posts
They make the adapters you need, here's an example.
MMWHS-32-BK - Mishimoto Water Temp Sensor Adapter - throtl - New Performance Parts at the Best Prices
Old 12-02-2018, 09:59 AM
simplebuck's Avatar
simplebuck
thanks, alloro,
That looks pretty good .... looks like it's intended to fit inline into the upper radiator hose.
Old 12-03-2018, 04:31 AM
JWA's Avatar
JWA
JWA is offline
Originally Posted by alloro
I had one of those, it worked fine but opted for the already-existing port. Mine was from Glow-Shift, decent quality but super cheap and suspect screw drive clamps included---I used a better grade for peace of mind.
Old 12-03-2018, 09:48 AM
alloro's Avatar
alloro
alloro is offline
I agree, if you have a threaded port in a coolant jacket you should definitely use it. But for those that don't, the in-line hose adapter is a great solution.
Old 12-14-2018, 06:51 PM
jerryparks's Avatar
jerryparks
jerryparks is offline
My 05 F150 does not have that threaded port. From my understanding the modular engines circulate coolant to the heater core full time, where the upper rad hose only circulates when the thermostat is open. So if that's true, would it be better to mount the sending unit in the heater hose to get a more accurate read?
Is there another port I can mount the sending unit into?
Old 12-15-2018, 04:44 AM
JWA's Avatar
JWA
JWA is offline
True that the Modular Motors circulate coolant all the time through the heater core and upper radiator hose only when t'stat opens. I don't know there's a better place to monitor coolant temperature--since I'm running an after market temperature gauge I prefer seeing it rise slowly rather than just pop up to temperature all at once. The instrument cluster gauge seems to do this same thing but there's no numbers associated with the pointer location which is one reason I added the other gauge.
Most are happy with using the radiator hose adapter shown earlier if there's no other port to access. BTW for a short while I used the Glow Shift adapter, cost about $20 through Amazon IIRC.
HTH
bigb56
08-01-2015 06:21 PM
lhud
Computer Chips & Tuners
10-08-2012 03:45 PM
KenS999
03-17-2008 03:58 PM
fourbyfourman
1997 - 2003 F150
07-08-2007 05:48 PM
MustangGT221
04-12-2005 06:26 PM
Quick Reply: Add Water Temp Gauge?
