Water Temp gauge not working....
Old Mar 12, 2008 | 10:03 PM
KenS999's Avatar
KenS999
Trailering
Hi- I have a 95 E350 van with a 460cid. Water temp gauge doesnt move from COLD. I removed sensor wire and grounded it, temp gauge moved right to HOT-so Im assuming gauge and sending line is good. Note: just a little bit of coolant dribbled out when original sending unit was taken out. Replaced sending unit (located near distributor and having a one wire terminal) with one from NAPA. I added coolant in expansion tank and ran engine for 15 minutes - still no movement in gauge? Any ideas why it still will not work? Is it possible it needs a Motocraft replacement part?
Ken
Old Mar 15, 2008 | 10:52 AM
Ultramagdan's Avatar
Ultramagdan
Welcome to the forum!
No, it doesn't need a Motorcraft part. I would check check the sending unit again.
Old Mar 15, 2008 | 09:28 PM
lsrx101's Avatar
lsrx101
Yep. And make sure that you got the sender for a gauge. If they gave you the sender for a warning light the gauge will not move. Did you use teflon tape on the threads? I have seen situations where the tape electrically insulated the sender from the engine.
Old Mar 16, 2008 | 10:37 AM
KenS999's Avatar
KenS999
Trailering
Coolant temp gauge...
I tried another new sensor, this one from Ford made for a temp gauge. Had the same poor result. Both sensors did come with a teflon thread coating. Manifold port has strong coolant flow out when old sensor was removed on cold engine. Radiator heats up and heater blows hot. Sender line when grounded makes gauge go to hot. Im stumped???
Old Mar 16, 2008 | 01:07 PM
88Vmax's Avatar
88Vmax
How is the ground on the motor?
Old Mar 16, 2008 | 01:33 PM
KenS999's Avatar
KenS999
Trailering
motor ground....
Hi,
Thank you for your advice. Would I verify ground from motor to frame or motor to neg battery terminal?
Thanks,
Ken
Old Mar 17, 2008 | 06:14 AM
88Vmax's Avatar
88Vmax
Originally Posted by KenS999
Hi,
Thanks,
Ken
I'd verify the neg battery terminal to motor connection. When you manually ground the sensor, what are you using for ground? If you are using the battery, try the engine block. If you use the engine block and nothing happens, then you've found the problem. If it does work...hmm then I don't know...
Old Mar 17, 2008 | 11:25 AM
KenS999's Avatar
KenS999
Trailering
I originally used the alternator bracket, which I believe is bolted to the block. Is there a definitive way to verify if the thermostat is stuck open. I get heat but it takes awhile for it to blow hot. Because I just got the van I dont know if thats a normal deal.
Old Mar 17, 2008 | 11:38 AM
88Vmax's Avatar
88Vmax
I've always tested a thermostat in a pot of boiling water, however if you remove the thermostat to test it, you might as well replace it. It doesn't sound like you have an issue with the ground on the motor.
Old Mar 17, 2008 | 03:58 PM
KenS999's Avatar
KenS999
Trailering
Thank You
Hello and thank you for taking the time to respond to my questions. The next warm day I will most likely replace the thermostat. -Ken.
yeha4x4
1997 - 2003 F150
May 28, 2015 11:27 PM
ford66
30
Feb 5, 2015 05:09 PM
machinist91
Oct 1, 2013 09:56 PM
thestateofchase
1983 - 2012 Ranger & B-Series
Dec 3, 2010 08:27 AM
apropos
Nov 17, 2004 12:10 PM
