4r100 torque converter staining
Old Aug 10, 2018 | 01:05 PM
JPs2003's Avatar
JPs2003
I’m replacing the oil pan on my truck (and a bunch of other things while it’s out) and noticed some thing showing signs of having leaked on the front of the torque converter. Any thoughts on this? I haven’t looked into it too deeply just yet but figured I’d ask.
Old Aug 10, 2018 | 09:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My guess is that the engine's rear main seal has a small leak.
Old Aug 11, 2018 | 12:04 PM
brandonrr's Avatar
brandonrr
What about a small leak that's been draining down from the valley, like the EBPV? I thought 7.3s rarely have rear main leaks, but I could be wrong.
Old Aug 11, 2018 | 01:31 PM
Mark Kovalsky
That could be it, too.
Old Aug 11, 2018 | 03:31 PM
carl2591's Avatar
carl2591
while of the subject of TQ would it be a good idea to replace OEM with triple disk billet type? everyone says this TQ is a weak link. I have a 2003 model. Have heard the 5r110 trans TQ will work and is a better choice as well.
I do tow a 8K airstream, but for now east coast mainly with not a bunch of hills for the most part. I use the torque app and when pulling I don't see much in teh way of slip vs non towing slip numbers from the TQ, so guess that mean it doing good for now.
did a fluid drop and fill several times last year with DEXRON III/MERCON and planning to do another drain flush and fill with Mercon V and put in 6.0 cooler I have on shelve this fall or next spring. the trans shift smooth and clean, replace valve body with John Woods to help firm up shifts and when towing in hills/mountains area keep eye on trans fluid temps.
Old Aug 11, 2018 | 06:09 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Someone had the engine (or most likely transmission) out at some point and greased the hub of the torque converter for some reason.
No reason for alarm.
csmrugby
May 28, 2015 01:31 PM
bkaul
Oct 21, 2010 02:47 PM
vwman80
13
Oct 8, 2006 09:42 PM
foots1
Dec 21, 2004 10:05 AM
Ed K
Mar 10, 2004 12:08 AM
