Need help
Old Aug 8, 2018 | 04:45 PM
William 76's Avatar
William 76
Need help
2003 f350 7.3 deisel it fires but won't run . I have put new IPR and CPS . Changed fuel filter took ICP off of my other 7.3 that is running still does the same . Fuel canister has pressure don't have gauge to see how much . Thanks in advance
Old Aug 8, 2018 | 06:15 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Are you sure you posted in the correct forum ? This is 2017+ .
Old Aug 8, 2018 | 06:40 PM
Stewart_H's Avatar
Stewart_H
Moved to the 7.3L PSD forum.
Stewart
Old Aug 8, 2018 | 07:16 PM
Walleye Hunter's Avatar
Walleye Hunter
How are you batteries? Oil level? Did it run last time you used it? Do you have any way to pull the codes?
Old Aug 8, 2018 | 07:35 PM
William 76's Avatar
William 76
Oil level good changed about 900 miles ago . I think batteries good but going to buy two new ones tomorrow. It died on me and changed fuel filter and it would crank over but wouldn't fire .let it set for about 3 hrs and started it up drove it about 2 miles and died again. All it does now is fires and dies. It fores for less than a second.
Old Aug 8, 2018 | 07:39 PM
Walleye Hunter
The IPR will do that when it kicks. Try cooling it with ice or canned air and see if it helps. OEM only for those parts and sensors. And check to be sure that the tinnerman nut is still on and tight on the back of the IPR.
Old Aug 11, 2018 | 11:22 AM
William 76's Avatar
William 76
Two new batteries the cps and ipr are motorcraft . Going to check fuel pressure today.
Old Aug 11, 2018 | 01:39 PM
timmyboy76's Avatar
timmyboy76
Dump the tank and do the Hutch modification
Old Aug 11, 2018 | 07:16 PM
Jaime74656's Avatar
Jaime74656
sounds like you may need to do hutch mods, what is your fuel level in the truck?? betting your pick up foot is toast...
Old Aug 12, 2018 | 01:58 PM
William 76's Avatar
William 76
Going to drop the tank this evening
Old Aug 12, 2018 | 03:33 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Are you planning to do the Hutch/Harpoon mods? You'll need some tubing etc. Here's a popular how-to link. I'd recommend doing the mod, not just cleaning the screens and putting them back in.
Old Aug 12, 2018 | 05:03 PM
William 76's Avatar
William 76
Dropped the fuel tank everything looked good .
Kenneth Commons
Nov 26, 2018 12:47 PM
Pineys-Pit
59
Oct 17, 2011 03:29 PM
Stevemb
Nov 4, 2010 09:00 PM
eggturner
95
Oct 20, 2010 10:08 PM
FastOldGuy
13
Nov 16, 2006 08:05 PM
