Need help
Need help
2003 f350 7.3 deisel it fires but won't run . I have put new IPR and CPS . Changed fuel filter took ICP off of my other 7.3 that is running still does the same . Fuel canister has pressure don't have gauge to see how much . Thanks in advance
Oil level good changed about 900 miles ago . I think batteries good but going to buy two new ones tomorrow. It died on me and changed fuel filter and it would crank over but wouldn't fire .let it set for about 3 hrs and started it up drove it about 2 miles and died again. All it does now is fires and dies. It fores for less than a second.
The IPR will do that when it kicks. Try cooling it with ice or canned air and see if it helps. OEM only for those parts and sensors. And check to be sure that the tinnerman nut is still on and tight on the back of the IPR.
Are you planning to do the Hutch/Harpoon mods? You'll need some tubing etc. Here's a popular how-to link. I'd recommend doing the mod, not just cleaning the screens and putting them back in.
Kenneth Commons
Nov 26, 2018 12:47 PM
Pineys-Pit
59
Oct 17, 2011 03:29 PM
eggturner
95
Oct 20, 2010 10:08 PM
FastOldGuy
13
Nov 16, 2006 08:05 PM
