Oil Temp Warning
Old Aug 8, 2018 | 10:15 AM
dirthawg's Avatar
dirthawg
Pulled this from the 6.7L Diesel Supplement for anyone that might not be aware of the additional idle time before shutdown necessary when towing.
SWITCHING OFF THE ENGINE
Turn the ignition to the off position.
To prolong engine life (especially after
extended high speed, high ambient
temperature, or high GVW/GCW operation,
such as heavy loads or heavy trailers), it is
recommended that a hot engine be idled
for 3-5 minutes. This allows the
turbocharged engine to cool down. For
more information on GVW/GCW, see the
Load Carrying chapter in your Owner’s
Manual.
Old Aug 8, 2018 | 02:49 PM
FiveOJester's Avatar
FiveOJester
Looking thru the 6.7 tech manual, I see the turbo's are water cooled. I know that alleviates a lot of the issues of a "hot shutdown" as they design the coolant chambers so that water will continue flowing when the engine is shutoff via a "thermo-syphon". As the water heats up, it rises and will draw cooler water from the engine.
Still a good idea to let it cool, but I think its less of an issue than with the old style turbos that were only oil cooled.
Interesting Garrett White Paper on water-cooled turbos:
https://www.turbobygarrett.com/turbo...er_Cooling.pdf
Old Aug 8, 2018 | 04:06 PM
The Bone's Avatar
The Bone
Originally Posted by troverman
You really don't need to wait for the glow plug light. Only in the extreme cold (say +10F or below) would it really be a problem if you didn't. And while I agree that idling for a couple of minutes after a very hard pull is a good idea, you probably don't need to. Ford specifically tests their engines for survivability of shutting down after an extreme run. Turbo cooling through coolant convection is much improved over the early days. As for oil, Ford diesel oil isn't even a blend unless you specifically request it. It's just standard 10w30 diesel oil.
I was told at the dealer that there is a diesel blend and not full synthetic that is what they normally put in diesel trucks. it's about $6 a quart. Maybe $7. I don't use that, I use full synthetic thats why my oil changes are around $200
As for the glow plug it's a habit.
Old Nov 18, 2023 | 04:17 AM
anyoceans's Avatar
anyoceans
Best to idle for a bit to allow the turbo to cool.
Old Nov 18, 2023 | 09:21 AM
Overkill2's Avatar
Overkill2
You just responded to a 5 year old thread but someone may respond...
bmensay
6.7L Power Stroke Diesel
Apr 10, 2018 06:58 PM
auriferous
6.4L Power Stroke Diesel
Jan 25, 2012 08:06 PM
spunks00
13
Dec 18, 2010 05:37 PM
Neal 97 250
Nov 27, 2007 08:43 PM
Stiffler
Jan 2, 2004 03:25 PM
