F350 SRW CC - Cargo Capacity #3063 & #3090
#31
Received 6,709 Likes
on
#32
#34
#35
When loading the basement I load the heavy items i.e generator, tools cast iron hibachi etc. on the passenger side.
#36
So I’ve found a 2018 F350 very similar to yours. It has a CC of 3417. What is your opinion, any problems, safety issues...? The Anderson Ultimate is 35 pounds, the wife and I are 380 and if I use your 2800#, still puts me less than 3417. This particular vehicle doesn’t have the 5th wheel hitch prep, so an additional computation will be required.
Thanks,
Tony
#37
After seeing this image and thinking to myself the tires are taking all that force. I could be wrong.
I pull a 6k landscape trailer around town daily and tight turns that put the trailer suspension into similar conditions as the image above are required to maneuver tight city streets and cul-da-sacs.
Last year, first time in 22 years, I broke my very first stub axle. I have no idea when it happened but fairly sure it was in an area of road construction that required many tight turns just prior to pulling over for a quick stop at a shopping center. I didn't know the rear tire was missing until I stopped at a shopping center and was walking back to my truck and trailer and noticed the following.
Please don't make it a habit of making those tight of turns or you could be in for a set of these.
The above image is a standard 3500# axle and 10" electric brake kit, I replaced the equalizer and all shackle straps at the same time since I was this far into the suspension. Total cost of parts above, $350, about three hours of my labor and a welding machine was required to make the repairs. I would assume a 5k axle setup would be more expensive to replace.
#38
Not a problem without the OEM 5th wheel hitch. Just have the Trailer dealer install a B&W 5th kit. https://www.etrailer.com/g-2018_Ford...Rail+Kit&furl= They install these all the time..
#39
#41
You should be fine with that truck with an Andersen hitch and a Reflection 337. . Not a problem without the OEM 5th wheel hitch. Just have the Trailer dealer install a B&W 5th kit. https://www.etrailer.com/g-2018_Ford...Rail+Kit&furl= They install these all the time.
My 2800#s pin weight is with lots of stuff loaded in the trailer pass through storage.
If you are buying a new Ford make sure you take advantage of the $3000 PCO.
#42
on
This may have been answered already, but what is PCO and how does one take advantage of it? Does it apply if I am purchasing the vehicle in the Ford D plan? (from what I understand D plan pricing already has the greatest discount available) Placing 2019 f350 order this week. Thanks!
#43
PCO (Private Cash Offers) are ineligible for A/Z/D plans.
Rockinfigs
Toy Hauler Towing; Fifth Wheel & Bumper Pull
09-19-2019 07:03 PM
Doonz
1999 to 2016 Super Duty
08-09-2012 02:42 PM
