Need Advice on 19000 GVWR Toy Hauler
Sorry for the double posting. Hey guys I currently own a 2019 F350 SRW LB ..Im looking at a 2020 attitude eclipse 3218mm which has a GVWR of 19000 , dry weight of about 12k and hitch weight under 2900...Is this F450 territory or can my f350 pull this thing safely? I will be hauling a 2014 rzr 800 4 seater. thks
You should be ok with the 350. I have an older F250 7.3 and tow a heavy 40.5 toy hauler My pin weight is at 3K. I am not overloaded on axles but about 900 over total GVWR. newer units have a much higher capacity than the older ones. Best thing it to weigh you truck and figure out your axle weights without a trailer. Than add the 3000 pounds to the rear axle. You should be ok on total GVWR.
Since it is a TH with 7,000lbs of CCC I would expect the pin weight to be on the high side with only the side by side in the garage, not a whole lot being carried back there to lighten that pin. I'm not a fiver owner, and certainly not a member of the weight police, but it seems to me that a 19K rated TH is a lot for a SRW truck to be towing.
I agree with xrated, look at the CCC sticker of YOUR truck, that will be your limiting factor. My bet is, you’ll be over. Don’t focus on the 19k GVWR, also look at the truck’s CCC and your GCWR. I also would 2900 is the empty pin weight, you need to see what the actual pin weight is on the trailer. I’m certain it’ll be north of 3k. With the bigger toy haulers like that, a load in the garage won’t reduce the pin weight as much as you think. When I have 1k in the garage, my pin weight doesn’t even drop 100 lbs. If the 2900 pin weight is the advertised weight, it’ll definitely be heavier. Once you add in propane, gear and anything ahead of the axels, and maybe a generator if it’s in the front like mine, you’re way over 3k, if not close to 4k.
With my set up below and a 3k pin weight, I’m right at the max GVWR of my 350 SRW, 11,500. My trailer empty is 14046 and my normal camping load is around 16K (with no water on board). If I ever went with a longer or heavier toy hauler, I’d be upgrading to a DRW, likely a 450. I’d prefer a 450 over a 350 DRW for the turning radius, bigger brakes, and wheels.
Rockinfigs
Toy Hauler Towing; Fifth Wheel & Bumper Pull
12-03-2018 07:44 AM
