Body mounts
Old Jul 9, 2018 | 06:44 PM
1911fan's Avatar
1911fan
Body mounts
Anyone ever get a clunking noise from bad body mounts? Ive looked all over the truck and cannont find anything loose. The only thing i see is 4 of the 8 body mounts are deteriorating. Ive even removed the shocks, sumo springs, tail gate and spare tire but still get a hollow clunk when the drivers rear tire hits bumps. The rear most body mount on that side is one of the ones that bad.
Old Jul 9, 2018 | 07:52 PM
blackfords's Avatar
blackfords
Yes. 2016 ford f350 diesel crew long bed dually wide track. Turning into a corner I get a clunk
Old Jul 9, 2018 | 09:49 PM
1911fan's Avatar
1911fan
its body mount related?
Old Jul 10, 2018 | 06:40 AM
kper05's Avatar
kper05
I have a new pop/squeak when turning or driving over a bad spot on the highway, even turning left at slow speeds in a drive through will cause a clunk but only sometimes. I cannot figure out what it is but I know it's right rear area. It's not shocks and it's not the air bags on the rear leafs. I have tried to reproduce it one day when the issue was the loudest with someone listening outside but failed. My next approach is to drive around with a go pro mounted on the frame to at least capture the noise more clearly than I can in the cab. I've had the issue for over a month, it might drive me insane mostly because I have no idea what specifically is doing this and not because of the noise. The clunk/pop makes sense but can failing body mounts squeak? My cab has never been removed.
Old Jul 10, 2018 | 09:56 AM
1911fan's Avatar
1911fan
i dont know ive lost half of my body mounts on an 85 chevy k5 while off roading and drove all the way home with no squeaks or knocking
Old Jul 10, 2018 | 10:31 AM
jav_eee's Avatar
jav_eee
I've got a weird "groan" when my rear tires go through a turn over a dip or bumps. I wonder if it's body mount related...
Old Jul 10, 2018 | 01:01 PM
blackfords's Avatar
blackfords
Javee, yours sounds like abs. My truck has a knock under my feet when the nose dips into a turn. Not sure if it is end links or a cab mount. My cab has never been removed either.
Old Jul 10, 2018 | 01:13 PM
jav_eee's Avatar
jav_eee
I seem to remember my F150 having that ABS issue. I guess that's what this is. Weird.
Old Jul 11, 2018 | 09:53 PM
KR2012F250's Avatar
KR2012F250
Yes, as the frame flexs it comes in contact with the cab bushing washers. I had to replace all mine with doorman replacements. I got the part numbers from AutoZone.
Old Jul 21, 2018 | 02:51 PM
kper05's Avatar
kper05
Took a recording (attached) of this noise last weekend with the tractor hooked up from inside the cab. This was 50 MPH or so if I remember correctly.
File Type: mp3
Old Jul 21, 2018 | 06:44 PM
KC8QVO's Avatar
KC8QVO
1911fan - How old is the truck and how many miles? You say the knocking occurs when the left rear wheel hits a bump, but not when any other wheels do? A buddy of mine with a 2008 CCLB SRW F350 had the bed rails rust through underneath that support crossways under the bed. You may check the integrity of the bed structure and see if anything is rusted through or otherwise loose.
okanagan91
Dec 7, 2018 11:06 PM
Gold Getter
6.7L Power Stroke Diesel
Mar 30, 2018 08:22 AM
Joshua Sirchuk
Aug 19, 2016 03:33 PM
RKCORPS25
Nov 15, 2013 07:24 PM
spartan
Aug 5, 2005 09:31 PM
