Outside air temperature wrong
Old Jul 7, 2018 | 04:22 PM
NAZSD's Avatar
NAZSD
My outside air temperature is indicating higher than actual temperatures. E.g. 10-13 deg higher. Anyone else experiencing this problem?
I tried finding the sensor. Anyone know where it's located on a 2017+ Super Duty?
Thanks.
Old Jul 7, 2018 | 04:28 PM
crewzer's Avatar
crewzer
Lightbulb
I believe the temp sensor is on the underside of the passenger side mirror assembly.
HTh,
Jim / crewzer
Old Jul 7, 2018 | 04:29 PM
NAZSD's Avatar
NAZSD
I wouldn't have guess that location... thanks Jim! I'll have a look.
Old Jul 7, 2018 | 04:33 PM
wb6anp's Avatar
wb6anp
Most vehicle temps read higher due to the proximity of the black top to the sensor, My DW's Fusion sensor is about 20 deg higher, the sensor is supposedly on the lower radiator support, a few inches above the road. Car is too low to the groud for me to even look for it.
Old Jul 7, 2018 | 05:23 PM
Tricon's Avatar
Tricon
Mines always off, sometime lower, sometimes higher. Yesterday it said it was 124F. I find the temp on Android Auto is almost always spot, which is crazy when you think that a local sensor is less accurate than something you're getting over the internet. Its pretty worthless in the truck, unfortunately.
Old Jul 7, 2018 | 07:10 PM
Kegme13's Avatar
Kegme13
Mine is normally within + - 3 degrees of what my weather app says. That being said, I have to give it 5-10 minutes after I start the truck to read somewhat accurately.
Old Jul 7, 2018 | 09:35 PM
k7lvo's Avatar
k7lvo
From what I saw, 124 wasn’t that far off in SoCal yesterday!
Old Jul 7, 2018 | 09:39 PM
troverman's Avatar
troverman
The temp sensor should be quite accurate. It’s located reasonably high off the ground and extended out away from the vehicle. There’s no reason for it not to be an accurate indication of the ambient air temp near the mirror.
Old Jul 7, 2018 | 10:24 PM
jakematic's Avatar
jakematic
This. Mine is typically higher... but giant black truck LOL
Looking in the service manual I don't see the sensor right off, but not familiar with the new Ford manuals yet.
I usually compare mine to the temperature from my local sensor in the back yard.
Old Jul 7, 2018 | 10:29 PM
NAZSD's Avatar
NAZSD
Since the temp sensor is in the passenger mirror bottom, would the chrome mirror cover help keep heat down and the temp closer to ambient? For those with chrome mirror covers (or silver, white) do you have overly high outside temp readings? Thanks.
Old Jul 8, 2018 | 05:43 AM
wildcard30's Avatar
wildcard30
Same here. My fusion is accurate. The temperature also reads higher initially but drops to normal quicker then my truck.
Old Jul 8, 2018 | 08:49 AM
tibadoe's Avatar
tibadoe
I have noticed the air temp is usually higher when I first fire up and take off after the truck has been sitting in the sun. Then after a few miles it pretty much dead on.
Big Sky
Jan 2, 2014 05:26 AM
Snuggyworm
Jul 18, 2013 11:01 AM
BigDa
1997 - 2003 F150
Dec 1, 2006 11:53 PM
RobInAB
2004 - 2008 F150
Sep 6, 2006 07:59 AM
smittyranger1993
1983 - 2012 Ranger & B-Series
May 5, 2004 09:39 PM
