Outside Temp Sensor
Old Jan 1, 2014 | 04:38 PM
Big Sky's Avatar
Big Sky
Outside Temp Sensor
The outside temp is won't go below about 48 degrees when I know in fact it is below freezing. Could the sensor be going bad? Anyone run into the same issue?
Old Jan 1, 2014 | 06:51 PM
Tuquala's Avatar
Tuquala
I know you said it's below freezing, but did you recently wash the vehicle??? Past Fords I have owned occasionally would read in error after a power wash. If not, I would check for water or corrosion on the sensor terminals. It's behind the grille on the drivers side next to the air filter intake. Then, probably a new sensor??!!
Old Jan 2, 2014 | 05:26 AM
Shepherd2's Avatar
Shepherd2
http://www.ebay.com/itm/F3VF-12A647-AA-Ford-Ambient-Air-Temperature-Sensor-TX12-/160619089?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2565a44bd9
varminthunter243
Mar 15, 2016 11:26 AM
laserred
Aug 5, 2008 06:07 AM
razor
Jan 2, 2008 05:00 PM
SPL Tech
Feb 7, 2007 12:44 PM
smittyranger1993
1983 - 2012 Ranger & B-Series
May 5, 2004 09:39 PM
