Water Methanol Injection
I put one on a 6.4
yes end to end cleaning
depending on what you run...you can get more cooling or more power
if not deleted...you have to be careful on cooling during low operating temps as this will reduce regen temps and could interfere with regens
you need about 500ml spray nozzles for a 6.7
id opt for two 250ml nozzles vs 1. 500ml nozzle for better spray control
things to worry about...methonal is corrosive so I’d be careful with mixed over 30%. Blue washer fluid is about 23%.
i ran blue washer fluid during winter and just water during all other seasons.
Amazon has a nice intercooler short pip with 3 nozzle fittings ready to go.
the tank is another problem. The windshield washer tank is too small and the 1 gallon tank you get in kits barely an improvement. I wound up with a 5 gallon tank .
all in all its nice way of getting more power, keep your engine clean, cool . And it’s easy to reverse and does not need a tune change or a tuner.
So, do you think it would be safe with say a deleted tow tune towing 15k throughout the mountains?
Depends on which you buy and what fluids you use
Ok = a) boost triggered only , 500ml nozzle, washer fluid in winter, water other 3 seasons, start injection at 10psi boost, 100% at 40 psi boost
ok = egt and map sensor triggered with same as A) conditions
using more methanol than washer fluid and higher nozzle tha 500ml could be risky with out approval from kit manufacture
Most kit manufactures have a chart that illustrates engine HP and will define nozzle size.
can you blow a motor with methonal injection....,sure....improperly installed kit can hydro lock an engine....follow instructions and use the recommended accessories or have the unit professionally installed.
the water never enters the fuel system.
the water injection is a fine mist that gets absorbed by the air entering the intake resulting in lower air temps .
some of the mist washes out combustion and emissions components
First picture is the inlet end. Black is scorched on CCV vapors. Did not have a catch can. Visible hole was a nozzle port. Clean metal can be seen on the opposite wall.
Second picture is the outlet end. All metal is clean. Darkness is shadow from the crimp.
Tube has been laying in my garage for two years.
When installed, the throttle body was coated with CCV scorch and hardened EGR soot. No picture available.
Took about 5k miles for everything to get clean down to the metal, and then the truck started running its best, which lasted until I traded it in on my new 2018.
Have not done the install on my current truck, but plan to do so next month.
The best source of info that I know of for water/meth injection:
rbcracing-rsr dot com/water injection.html
I will not say that it improved my mileage.
I will not say that it made more power.
I would say that power and mileage were restored to stock from what had been lost to scorch and soot buildup/clogging. The overall effect is probably better than stock, but better to expect something and be surprised, over hoping for something else and finding yourself disappointed.
