So this is something new to me, i was looking at one of the ads on this forum and they were advertising a water/alcohol injection system that you could run 100% windshield wiper fluid ment for in the winter.
They also say that its 100% safe(so do most programers). My question is, whats the diff between that and nos? I can't see washer fluid being good for a motor, could it?
It actually does the engine no harm (these engines can ingest a great many things and keep on truckin'). The water/meth injection does a few things, first it cools the intake air charge which allows more air into the cylinders, second if you are using methanol it provides a little extra fuel to burn. It also reduces EGTs because of the extra energy it take to boil the water.
That's the short answer, but it does no harm to the engine and it properly used, actually does a fair bit for the performance of the truck.
so the main purpose of this is not performance, do you have to worry about too much methanol just like dumping too much nos in a motor not made for it? they also advertise it cuts down on coking, how?
Oh no; don't misconstrue what I've said.... You can get a lot more HP out of an engine running water/meth than not... Takes some tuning but there's no doubt about it, I've also heard from heavy tow guys that it can give you a nice perk up in the fuel economy as well.... As to the coking issue, when you're running lots of water/meth under high load conditions it's like a pressure washer for the inside of your engine, hoses everything down nice and clean. I've heard from a couple of engine gurus that the engines they've tore down that were using water/meth were among the cleanest they'd seen.
As long as you buy a good progressive system I think the likliehood of problems is minimal. As long as you don't start trying to run straight methanol or other fuels through the system I see few possible problems.
Only if you run so much that you hydraulic a cylinder would you have a problem, and you would need flow a HUGE amount of fluid to do that.
there are downsides to too much, but that is with anything. one guy on here blew his motor with water/meth AND nos.. but a simple water/meth or even straight water kit should do no harm.
the meth adds power as it is a fuel, and like what was stated above, the egt's drop drastically, AND it really does clean the heck out of the combustion chamber and piston and valves. it is a good investment whether for towing, performance, or simply keeping egt's down.
i am probably just going to run straight water in my system.
Well... The blown engine wasn't directly caused by the water meth/nos, it was that the water/meth and nos did not shut off when the engine shut down due to low oil pressure. The LPOP came apart when the engine over revved....
It's always good to hear others discussing the benefits of water injection. We didn't invent water injection... it's been around for quite some time and has proven its value many times over. What we did do is design a very easy system to install that has the most advanced progressive controller on the market. Our trunkmount system can typically be installed in about an hour (sometimes less and sometimes a little longer). This is a huge benefit because most other systems take about 3-4 hours to install.
If you have any specific questions feel free to call or pm me. All of the previous replies to the initial questions about water injection are true.
We've posted this in some other threads but it has a lot of good information so I thought it may help out this thread as well.
No supercharger or turbocharger system is complete without a water methanol/alcohol injection system . Whether or not you are running an intercooled system, the benefits gained from water injection are so profound you simply can't afford to run without it. The best part is that these benefits can be realized in less than an hour... the time it takes to install our system .
Water Alcohol/Methanol Injection Will Reduce Your Air Charge Temps and Provide the Following Benefits:
Our trunk mount kits make it easier than ever before to install. Unlike other systems, you won't have to worry about assembling the components first and then trying to find space to install the pump, container, hoses and wiring under the hood of your ride (nearly impossible on newer vehicles). This can be time consuming (between 4-6 hours) and costly (mechanics can charge $100+ per hour). Our trunk mount systems are typically installed in less than an hour!! That's because our system comes pre-assembled . So the only thing you'll have to do is install the tank assembly, injection nozzle, and the fluid lines connecting the two. You WON"T need to remove your bumper or fabricate mounts in your fenders!! We even provide you with REAL installation instructions, not some generic steps that were haphazardly put together.
Compare our trunk mount systems to the competitors systems and you'll quickly see the difference!
Our Kit vs. Leading Competitors:
Most advanced digital progressive controller on the market - compare for yourself vs. the competitors
Our all-in-one controller allows you to run not only a boost signal but also a MAF, TPS, MAP & EGT signal
System includes a serial port for connection to a laptop
System comes pre-assembled unlike the competitors which requires you to assemble everything
System can be installed in 45-60 minutes - That's 5-9 times faster vs. the competitors under hood kit
No unsightly pump, reservoir, hoses or added wiring under the hood
No need to convert existing wind shield wiper fluid container
Our system is completely hidden in the trunk for a stealthy install
1.5 gallon container vs. the competitors common 1-2 quart container
Much less frequent refills required as the leading competitors do
Have questions or need help choosing the right water methanol/alcohol injection system for your application. Gives us a call toll free for immediate service at 1-801.447.ALKY (2559)
AND just a few other things. Like 64mm Turbo, Stage II Injectors, etc. etc. Oh yeah, and overeving it. I highly recommend Water/Meth for heavy towers. It reduced my EGT's significantly. Oh course, the blown motor was nothing to do with the water/meth, and alot to do with a huge combo of factors including driver error. You can read about it in the competion thread if you want.
How long do the injectors last? and if you have an injector fail, will it be covered?
Water in ANY amount in a high pressure injection system is not a good thing. At the temps & pressures at the injector tip, any water vapor present will flash into one of the most corrosive things known to man - high pressure steam. It'll tear those injectors apart in short order.
Ford says no water, no alcohol, and makes a filter to try to remove it from the fuel. Wonder why?
Now, if you want a drag truck, where you're constantly working on the engine, and don't mind the cost of an injector or two on a regular basis, go for it.
