Another crank no start.
Old Jul 3, 2018 | 10:43 AM
CC'sDad's Avatar
CC'sDad
Just got done installing new heads intake injectors. Ran great. Was towering my 5r too the beach. After 2 hours on the road the truck cut off when I slowed to make a sharp turn. Then again when we slowed down. Then finally again wouldn't restart. It had a crank position code. Related the sensor, no change. Ficm is at 49 volts . what else should I be looking for?
Old Jul 3, 2018 | 11:15 AM
CC'sDad's Avatar
CC'sDad
This is some cracking.
Old Jul 3, 2018 | 11:20 AM
CC'sDad's Avatar
CC'sDad
Only code I'm getting now is fuel pump secondary circuit high p0232. I have the air dog fuel system on it.
Old Jul 3, 2018 | 11:26 AM
xcrsp440's Avatar
xcrsp440
ICP needs to be at least 500 to run.
Old Jul 3, 2018 | 12:14 PM
CC'sDad's Avatar
CC'sDad
So does that mean my hpop is bad?
Old Jul 3, 2018 | 12:31 PM
imq707s's Avatar
imq707s
Could be your ICP sensor.....unplug it, and see if it will start. Could be IPR valve. Could be STC fitting. Could be dummy plug/standpipe. Could be upper injector or fuel rail nipple cup seals.....lots of places for the high pressure oil system to leak.
Either take it to a good shop, or buy one of those air fittings to pressurize the oil system....and listen for where the air leak is.
Old Jul 3, 2018 | 12:47 PM
xcrsp440's Avatar
xcrsp440
I find these very helpful
Old Jul 3, 2018 | 04:39 PM
bismic's Avatar
bismic
Verify whether or not you are getting fuel to the secondary fuel filter bowl (have someone turn the key on while you watch the empty bowl - be prepared to tell friend to turn it off quickly). Not sure how you have the Air Dog "plumbed", but you just need to be sure it is working properly.
The ICP volts are dead on for the pressure. I doubt it is the sensor or harness. Might be not enough fuel to spin it and develop the necessary high pressure oil pressure. Your cranking rpm's are VERY marginal.
If you are getting fuel, then more-than-likely it is a real high-pressure oil issue (ie most likely a leak, but could be the IPR or much less likely, the HPOP). Most common leak points as mentioned above for your 2006 are dummy plugs, STC fitting, injector o-rings, then stand pipes.
Old Jul 4, 2018 | 07:33 AM
CC'sDad's Avatar
CC'sDad
I did all the updated stand pipes and dummy plugs a few years back. Did the sct during my head replacement a few weeks back. Maybe I nicked an o ring when I was doing that. New injectors at the same time. I'll check the fuel. And hook up a charger. Tried unplugging the ipr, no change.
Old Jul 4, 2018 | 07:36 AM
CC'sDad's Avatar
CC'sDad
As a note. I have very limited resources as we are on vacation in a campground. Trying to troubleshoot is tough. This would be a different situation if I had the truck home in my shop.
Old Jul 5, 2018 | 09:42 PM
IHateCommieCars's Avatar
IHateCommieCars
Just confirming you unplug the ICP and not the IPR
Old Jul 7, 2018 | 12:07 PM
CC'sDad's Avatar
CC'sDad
yes, ICP, not IPR.
Old Jul 8, 2018 | 12:42 PM
Yahiko's Avatar
Yahiko
So I am going to ask some odd questions.
Ready?
When you installed the heads did you also put fresh oil on the stand pipes when you reinstalled them? What is you battery voltage? If it's low that could be the reason for slow cranking. Unhook the trailer plug
when you crank to see if there is extra load on the batteries. Also check the clamps to be sure that all four are nice and tight. You may even want to clean the clamps and thermals. If you find that the batteries are
a little on the low side see if you can find a charger to get them up to a charged state.
Old Jul 9, 2018 | 09:07 AM
CC'sDad's Avatar
CC'sDad
Ready?
I think I did, but not 100% positive. The batteries had been run down a bit by the time I took the picture, the picture is 2 days after it shut down on me. I'm thinking I will go ahead and pull the valve covers and oil rails. Should I just inspect all the orings and reinstall, or should they be replaced. Obviously with a good soaking of fresh oil either way!
Old Jul 9, 2018 | 03:02 PM
Yahiko's Avatar
Yahiko
Start with easy things first. Do you have fuel?
Is it getting to the injectors?
Shutting down when turning one direction points to tank or a wiring issue.
You need to verify fuel pressure first.
By wiring I mean fuel pump wiring.
