Water Pump Problem
Old Jun 30, 2018 | 10:18 PM
HRTKD's Avatar
HRTKD
Water Pump Problem
My water pump keeps running but I get very little pressure. It was working fine last week to pump water out of the hose so I could wash the top of the trailer. I don't see any leaks. I let it run long enough that if there was a leak I would have seen it. There is at least 20 gallons of water in the fresh water tank.
I'm heading out for boondock camping tomorrow. This is going to be interesting.
Old Jul 1, 2018 | 06:01 AM
RV_Tech's Avatar
RV_Tech
Filter on the pump is clogged? Pump is just getting tired and needs to be replaced? If the pump does not cycle with all the fixtures closed, it likely does not have a leak, but I have had more than one service call to clean the filter on the pump. It is an easy thing to forget.
Old Jul 1, 2018 | 06:22 AM
ShotgunZ71's Avatar
ShotgunZ71
Have you tried to prime it again in case it lost prime?
Old Jul 1, 2018 | 06:38 AM
RV_Tech's Avatar
RV_Tech
Unless there is a leak on the intake side of the pump, it should not need priming provided it is plumbed correctly. Just a thought.
Old Jul 1, 2018 | 07:37 AM
HRTKD's Avatar
HRTKD
Priming it was something that occured to me last night. I had drained the fresh water tank completely, but then added more water and only then did I run the pump. So the pump shouldn't have been run when it was dry. It wouldn't need to be reprimed just because the tank was empty, right? I've never had to do that before. How do I prime the pump?
I do have a filter in the system, but the filter was in place when it was working fine last weekend. But I'll remove the filter just in case.
Old Jul 1, 2018 | 07:59 AM
ShotgunZ71's Avatar
ShotgunZ71
It shouldn't need to be primed again, even if freshwater tank ran dry and the pump ran briefly. Usually, you prime them with a clear hose that is connected at the pump. You pour water (obviously from another source) into it until the pump and feed line is full. Then, you reconnect hose and start the pump. Once it's primed, you will hear a difference in the pitch of the pump motor.
Old Jul 1, 2018 | 08:08 AM
HRTKD's Avatar
HRTKD
Ah! So that's what that hose is for that is stuck inside the cabinet where the pump is. I thought it was for draining the water filter and couldn't figure out how the heck that was supposed to work.
I'm definitely hearing a difference in the sound the pump makes. Yesterday when it was running I thought it sounded a little too quiet. I let it run for a good 5 minutes and shut it off with the thought that if it hadn't worked in 5 minutes another 5 minutes wasn't going to help.
Old Jul 1, 2018 | 08:34 AM
RV_Tech's Avatar
RV_Tech
All pumps are self priming. From the Shurflo manufacturer's manual:
WILL NOT PRIME/SPUTTERS (No discharge/Motor runs)
√ Is the strainer clogged with debris?
√ Is there water in the tank, or has air collected in the hot water heater?
√ Is the inlet tubing/plumbing sucking in air at plumbing connections (vacuum leak)?
√ Is inlet/outlet plumbing severely restricted or kinked? Restrictive valves?
√ Proper voltage with the pump operating (±10%).
√ For debris in pump inlet/outlet valves or swollen/dry valves.
√ Pump housing for cracks
You will note it says nothing about needing to prime the pump because it is not necessary. While I have had to prime a pump on occasion it has only been in cases where the initial installation was done incorrectly, usually the way the intake line is run. I just pulled the water tank and everything leading up to the pump as well as the pump itself in my truck camper a few weeks ago and did absolutely nothing to prime the pump. After put it all back together, I put water in the tank and turned it on, the pump primed itself and began pumping in less than a minute. That is the way it is supposed to work.
Old Jul 1, 2018 | 10:34 AM
HRTKD's Avatar
HRTKD
I hooked up shore water and that produced pressure at the sink OK. While that was connected I turned on the pump. It recognized that there was already pressure in the system and shut off. Turn off shore water, open a valve at the sink and after a few seconds the pump turns on and won't stop.
I believe that both shore water and on-board water both go through the filter.
Air in the hot water tank: What do I do about that? I thought a little water in the hot water tank was a good thing.
Old Jul 1, 2018 | 11:37 AM
HRTKD's Avatar
HRTKD
I disconnected from shore power/water, moved the trailer 10' and now the water pump isn't running constantly. I'm hoping that "solved" it.
Old Jul 2, 2018 | 06:21 AM
ShotgunZ71's Avatar
ShotgunZ71
That does seem odd. So, is the pump working properly now on both hot and cold?
Old Jul 3, 2018 | 04:13 PM
TCNashville's Avatar
TCNashville
That hose is mostly used for winterizing the camper.
If your water heater is empty it takes a while for the pump to fill it and then pressurize the rest of the system. You should have the faucet nearest the hot water heater open on the hot side to purge the air from the heater as it fills. Once there's a steady stream on water coming out of that faucet you know the heater is full.
Old Jul 5, 2018 | 08:52 PM
HRTKD's Avatar
HRTKD
Worked great! I went through a good 50 gallons of water at camp. No problems with the pump.
I had opened the hot side faucet in the kitchen sink while troubleshooting. It isn't the closest faucet though.
Epd444
Apr 26, 2012 11:18 AM
berry1234
Mar 14, 2010 12:43 PM
throwdown
23
Mar 12, 2009 08:28 AM
gofast51004
Mar 5, 2009 08:53 AM
claydr54
Oct 15, 2007 09:03 AM
