Bearing temp question
Old Jun 24, 2018 | 01:58 PM
frysl's Avatar
frysl
Hello all
I just repacked the wheel bearings on my TT. On the advice of a friend I bought a temperature gun to monitor wheel bearing temps. I’ve checked the temps several times now and 3 of the 4 are all within a few degrees of one another at around 105 F. The 4th is always about 10 degrees above the rest. Is that difference big enough to consider backing the castle nut off one notch, or is it good to go?
I’ve always been on to just grab the hubs to check for an over temp, so I might (probably am) be making a deal out of nothing.
Appreciate any advice.
thanks
Steve
Old Jun 24, 2018 | 03:11 PM
Tedster9's Avatar
Tedster9
Maybe the other three are too loose?
Technically, we're supposed to be using a dial indicator and getting it close to just a few thousandths. Nobody does this. Slightly loose is a lot better than too tight though.
Old Jun 24, 2018 | 05:39 PM
RV_Tech's Avatar
RV_Tech
I think you are fine. The likelihood wear and load on each wheel is exactly the same is remote. If things are going south, you will see a good deal more than that.
Old Jun 24, 2018 | 08:20 PM
ncl's Avatar
ncl
Maybe check your brake adjustment. Perhaps that one wheel is braking more than the others.
Old Jun 24, 2018 | 09:56 PM
frysl's Avatar
frysl
yea, I’m still trying to figure that out. The shoes on the passenger side are definitely thinner than the other side. I’ve adjusted them all, so we shall see.
Thanks
steve
Old Jun 26, 2018 | 08:08 AM
Chuck's First Ford's Avatar
Chuck's First Ford
I go by... 20 degrees above ambient air temperature...
then add 20 degrees if the Sun shown on one side for an hour or more....
use brakes as little as possible before doing a Temperature reading.
and 30 degrees more does not mean there is an issue... now over 150-160 is a problem... fyi
my opinion.
Old Jun 26, 2018 | 08:15 AM
RV_Tech's Avatar
RV_Tech
I think the things that make it so hard to nail down are the multitude of different factors affecting hub temperature. For example, what is the normal variation in factory specs, then there is weight load per bearing, small differences in grease penetration, brake shoe drag, differences in magnet strength, etc. I use an infrared at times, but most often if it burns your hand when you touch the wheel something is wrong. If you set it up correctly, attend to your bearings on schedule, and do not run them too tight, my guess is your are fine.
Old Jun 26, 2018 | 04:06 PM
Chuck's First Ford
I understand all the variables.. retired auto mechanic.aka drum brakes since 1967... Front and Rear
but a sense of simplicity is needed here.. so the above numbers work for me.
trailer towing something since 1983.....
YES,,, if the hub is painful to touch for a second.. there is an issue...
Old Jul 2, 2018 | 08:36 PM
ncl's Avatar
ncl
I am actually experiencing a similar issue. I noticed one wheel warmer than the rest on my TT. So I checked and adjusted all 4 brakes so they slightly dragged. Went on a 2 hour trip and all seemed fine on trip down. Towed back home and after backing in driveway walked by wheel and could smell what seemed like brake smell. Took temp of all wheels and all were 110 except the suspect wheel again. It was at 140. So today after speaking with my father. He suggested to jack up wheel and apply brake and check to see how much brake is grabbing compared to others. I used my tiny irwin wood clamp to keep slider on brake controller to 3 bars of output to brakes. The wheel that was hot I could not budge. I then checked the rear wheel and I could move it. It took some effort but I could move it none the less. So I backed off the hot wheel brake to achieve same amount of drag when power applied to brakes. It seems even though I adjusted them to what felt all the same that one wheel seems to grab harder than the others. We have a trip in a couple weeks so I will double check with temp gun to see how it does. I may also do a test run to see how it does.
Old Jul 5, 2018 | 09:58 PM
LeoJr's Avatar
LeoJr
This is great creative problem solving...thanks and please keep us updated with what you find!
Tim Hodgson
Feb 8, 2015 06:31 PM
longboardguy
Oct 15, 2008 05:06 PM
Ned Nimrod
Sep 28, 2006 11:07 PM
surfclam
15
Apr 7, 2005 09:04 AM
