Leaky water pump
Old Apr 25, 2012 | 02:14 PM
Epd444's Avatar
Epd444
Leaky water pump
My water pump seems to be leaking at the lower hose connection on the water pump. Is there an O ring in there I can replace or do I need to replace the whole water pump?
I'm getting ready to do a coolant flush anyways so anything else I should do?
Old Apr 25, 2012 | 02:42 PM
Talyn's Avatar
Talyn
Usually if they leak, they are bad.
Old Apr 25, 2012 | 02:43 PM
Talyn's Avatar
Talyn
Nice to see your still alive bytheway.
Old Apr 25, 2012 | 02:56 PM
Epd444's Avatar
Epd444
Hah, yea I know its been a while, been really busy
Old Apr 25, 2012 | 05:15 PM
srteach's Avatar
srteach
You have one or more problems. Check where the leak is actually from. The coolant can leak from the weep hole and run down to the lower radiator hose, or it could actually be the radiator hose.
The weep hole is on the bottom side of the main pump shaft, it should be dry.
Old Apr 25, 2012 | 09:32 PM
oldbird1965's Avatar
oldbird1965
To answer the question, no, there isn't a O ring in the connection of the lower radiator hose to the water pump, just a hose clamp.
Old Apr 26, 2012 | 10:23 AM
JamesHajek's Avatar
JamesHajek
I would bet it's leaking out the weep hole and it is ending up on that lower rad hose... That's what mine did... But you could also see the coolant dripping right down the front cover...
Old Apr 26, 2012 | 11:18 AM
pjwoolw's Avatar
pjwoolw
There is an o ring on the inlet tube. But I suspect its time for another pump.
One Sock
Feb 14, 2012 09:23 AM
dustinova
Nov 18, 2007 10:16 AM
firebug
Aug 5, 2004 09:04 PM
RockinB
Dec 22, 2003 10:04 PM
