So I made a quick run to Walmart. Came back out and the truck started fine. Put it in reverse and dialed out of my spot. Put the truck in drive and no throttle whatsoever. I also don't have any gauges working. Fuse?
You may want to check that wire that normally rubs (I think it goes up in the shifter arm to the OD button) through in the column that kills your pedal?
Sorry for appearing like I have ignored this. I replied to a comment on here the other day, that I had in fact determined the problem to be the OD button harness. For whatever reason, it didn't post. Thanks to everyone that commented on here. I promise I didn't ignore you guys.
Well holy crap! I have had that happen about 3 times to me over the past 12yrs I have owned my truck. I also have replaced the wiring for my OD button and never put the two together. I haven't had that fuse blow in a long time...hmmm maybe since I replaced the wiring? Ugh. Nice to finally know what my issue was... well at least that one. There are many more I have yet to figure out. But the truck runs great!
