HELP!!! No gauges or throttle response?
Old Feb 9, 2016 | 07:07 PM
Colorado350's Avatar
Colorado350
Exclamation HELP!!! No gauges or throttle response?
I installed A transmission temperature gauge today. Everything went in fine however now when I started the truck lights,wipers, lashers work etc. I have no gauges whatsoever they're all dead and I have no throttle response I put it in gear the truck does not want to go anywhere. I used an add a circuit in the fuse box on the driver side under the dash for power disconnected it reestablished the original fuse and still nothing. I could really use some help !! I used an add a circuit in the fuse box on the driver side under the dash for power disconnected it reestablished the original fuse and still nothing. I could really use some help right away. Thanks!
Old Feb 9, 2016 | 07:18 PM
Colorado350
Ok, well all I needed to do was post this up so that I can look like a complete idiot.
The add a circuit requires two fuses I only put one fuse in which ran the tranny gauge but I didn't put the other fuse in which ran everything else. At least it was a simple fix. Maybe I should start drinking.?
Old Feb 9, 2016 | 07:20 PM
SMT_FORD's Avatar
SMT_FORD
Deleted Post
Old Feb 9, 2016 | 07:23 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
My favorite kind of mistake to make is the easy ones to fix. It is the difficult ones to fix/find that will get you.
Agentmexico
Apr 10, 2017 11:44 AM
Valv
Electrical Systems/Wiring
Mar 13, 2008 02:14 PM
CowboyUp1387
Feb 4, 2008 11:18 AM
revandthern
Sep 29, 2004 02:36 PM
