Pulled trigger on PHP Hydra
Old Aug 25, 2018 | 08:41 PM
Shawn.54's Avatar
Shawn.54
Just ordered PHP Hydra for now going with standard tunes for my stock 2002 F350.
Can’t wait to install.
shawn
Old Aug 25, 2018 | 08:50 PM
timmyboy76's Avatar
timmyboy76
What finally made you pull the trigger? How long have you been mauling over the idea?
Old Aug 25, 2018 | 10:01 PM
Shawn.54's Avatar
Shawn.54
Been mauling it over since early April when I got the truck was thinking ts6 but felt with research that hydra was more up to date with more options.
I’ m not looking to generate massive power just a little more and maybe gain a little mpg.
shawn
Old Aug 25, 2018 | 10:05 PM
Silverhks's Avatar
Silverhks
I'm trying to get on top of a few more maintenance issues and I will be joining you as a new Hydra owner
Old Aug 25, 2018 | 10:13 PM
Shawn.54's Avatar
Shawn.54
I’m still chasing a few troubles myself the biggest reason I moved was that I want to go into winter with high idle option for quicker warm up an maybe a little more power to ice the cake.
Going from 04 f150 5.4 to 7.3 is a step up in handling the light 5er I have and I think the mod bug got me too.
shawn
Old Aug 25, 2018 | 10:35 PM
brandonrr's Avatar
brandonrr
You guys wont regret the hydra. I love mine and everyone I know with one has been happy with it.
I like the daily 80hp tune for regular unloaded driving with my truck. Good power, economy and shifting while keeping smoke minimal. The tow tunes are decent as well. I am still dragging my feet on getting custom tunes because I've been mostly satisfied with the included php tunes.
remember, it is VERY important to clean the pcm very well, but also not too aggressively. I was one of the many who didn't clean the pcm enough the first time and had an interesting trip home with my truck stalling about once a minute in moderate city traffic. You want to make sure you are all the way to the solder while removing as little solder as possible. You will see some copper streaks under the solder and it's fine as long as the majority of the surface is still solder.
If you plan on towing while tuned, you'll want an EGT gauge. High EGT is a silent killer for diesel engines. You want to stay below 1250f for sustained pulls and try to keep the peaks below 1300f. I managed to get my exhaust temps up to 1300f on the "25hp" tow tune with 6637 air filter and 4" exhaust. The tow tunes seem to exceed their hp rating in the last 10% of the throttle. The "25hp tow" tune seems to be as powerful as the 80hp tune at full throttle, but only slightly quicker than stock up until that ~90% throttle range.
if you still have a stock 4r100, I'd advise keeping to tuning to 80hp or lower. A modified valve body and upgraded torque converter can add a good bit of durability to an otherwise stock transmission to withstand just about anything the stock fuel injectors can dish out.
Old Aug 25, 2018 | 10:47 PM
Shawn.54's Avatar
Shawn.54
I have the gage already just not the time to install should have that done befor chip gets here.
My truck has Zf6 my only fear is I don’t know if clutch is factory or replacement it feels good but is unknown.
shawn
Old Aug 26, 2018 | 01:23 AM
mcnance865's Avatar
mcnance865
Your truck will feel way more powerful with the Hydra. I noticed a massive difference the first time I touched the pedal and loved it. That was on stock injectors with the standard upgrades: 4" exhaust, intake, gauges, hydra. I was already tuned with an SCT programmer. The hydra made a massive difference even over that.
Old Aug 26, 2018 | 09:14 PM
Shawn.54's Avatar
Shawn.54
I’m hoping to gain a little low end to help her get rolling a little quicker.
The other concern is powdered metal rods I don’t want to exceed their strength where is the cutoff on power for them?
Old Aug 26, 2018 | 10:45 PM
brandonrr's Avatar
brandonrr
According to PHP, all of their included tunes are safe for PMRs, except for their "140hp" extreme tune. On stock injectors, no tune, regardless of what is advertised, is going to make more than about 80hp more than stock. If there is any reason the 140 tune might be risky for PMRs, it's the overly aggressive low rpm fueling.
Old Aug 26, 2018 | 10:48 PM
Wes444's Avatar
Wes444
The pmr cutoff # thrown around is approximately 400hp, which you will never (very very unlikely that is) make without bigger injectors/turbo
Old Aug 27, 2018 | 11:00 AM
Shovelheadrob's Avatar
Shovelheadrob
I went for the DP tuner when I was looking for a chip, the only reason I went that route was because I liked the deceleration tune, does anybody know if someone does that for the hydra now? I like the reviews on the hydra & thinking time for a change.
Old Aug 27, 2018 | 11:46 AM
Dan V's Avatar
Dan V
There's some dude in Montana....
Old Aug 27, 2018 | 12:17 PM
brian42's Avatar
brian42
Veteran: Navy
Depending on the condition of your injectors 60Hp is about all the extra Hp stock injectors can muster.
According to PHP, all of their included tunes are safe for PMRs, except for their "140hp" extreme tune...If there is any reason the 140 tune might be risky for PMRs, it's the overly aggressive low rpm fueling.
From my understanding that's the PMR killer, low end fueling.
Old Aug 27, 2018 | 01:13 PM
mcnance865's Avatar
mcnance865
I don't think horsepower directly is this issue. There are plenty of people running 500+ on PMRs. It is the increased cylinder pressure caused by low end fueling/advanced timing that the PMRs cannot stand up to. Get the tuning right.
