blown fuse
Old Sep 27, 2004 | 10:20 AM
revandthern's Avatar
revandthern
blown fuse
03X. 6.0. When I shift from reverse to drive fuse #45 blowes. This one controls the gauges only. Everything else works fine. Need advice. Also let me say that this is a great site with lots of helpful input.
Old Sep 27, 2004 | 11:06 AM
jdadamsjr's Avatar
jdadamsjr
Welcome rev....
same truck - not even close to those symptoms - so I'll be little help...
but sounds like something may have changed on it...
first questions to ask...
when did this start ?
and what was chaned just before that?
I've usually found a cause and effect to something I just "fixed" or "improved"
I have that Tim Allen syndrome where I cant leave well enough alone
Old Sep 27, 2004 | 12:33 PM
revandthern
blown fuse
it started about a week ago. I have made no changes. Started up the motor and noticed the gauges where not working. I put in a new fuse and it lasted about two days and blew again. It does not happen all the time just after I have run it for a little while, sometimes the next day. I talked with the dealer and was told to replace the fuse, but several fuses later and can't find the problem, I'm alittle worried.
Old Sep 27, 2004 | 12:37 PM
1081's Avatar
1081
You might try to get your hands on a wiring diagram and see what else is on that fuse because I doubt it is only for the gauges. You obviously have a short in the system somewhere, if it is blowing it that often it should be easier to find.
Old Sep 29, 2004 | 02:36 PM
revandthern
Talking
Fixed Problem. Wiring harness in shift lever was nicked and shorting out. Put a piece of tape on it and wala
