OD Light Blinking, No Codes?
Old Jun 22, 2018 | 08:51 PM
kennyfzj80's Avatar
kennyfzj80
96 e150 351w E4OD
So the other day my OD light started blinking and 1st and 2nd started hard shifting at low rpm. At higher RPM is shifts relatively smooth.
So I pulled over and turned off the engine. Started the engine again and my tranny shifted the smoothest it has ever shifted for about 10 minutes and then OD light started blinking again with the hard shifting.
I plugged in my Scan Guage 2 and no codes are coming up. Do I need another device? I thought the tranny codes were stored in the PCM like everything else?
Old Jun 22, 2018 | 09:07 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The transmission codes are stored in the PCM. You do need a better scan tool.
Old Jun 23, 2018 | 08:06 AM
Eddiec1564's Avatar
Eddiec1564
When the OD light flashes and trans hard shifts, does the speedometer show any jumping? Also if you have speed control(cruse) which works, does it hunt the set speed?
Most likely once you read the codes(OBD1) you will get a VSS problem code. This means the ECU is not getting correct speed information from the PSOM(speedometer ). This is a common issue now days as the PSOM(speedometer PCB) ages with bad connections and capacitors.
Before replacing the VSS sensor in rear axle(which everybody does first and problem is NOT fixed), do a search here for "hard shift transmission" in the 87 to 96 Pickup truck forum. There are many threads about this with diagnostic and repair info.
Old Jun 24, 2018 | 07:06 PM
kennyfzj80's Avatar
kennyfzj80
What is the part number for the VSS?
I'm getting:
F4AZ-7H103-A
and
DY1123
Seems like the same part?
RÖENTGEEP
Mar 23, 2018 01:49 PM
Leemakesmepee
20
Oct 19, 2011 01:41 PM
drembedded
22
Aug 17, 2011 09:43 AM
rtpalin
1997 - 2003 F150
Mar 29, 2009 04:01 PM
Highmark18
Jul 16, 2005 11:10 PM
