Overdrive light blinking but no codes
Old Aug 5, 2004 | 09:29 PM
drembedded's Avatar
drembedded
Exclamation Overdrive light blinking but no codes
My '01 PSD excursion's 4r100 transmission started giving me fits. It started with shifting hard from 1st to 2nd at high Rs then the OD light started blinking. I used my OBD-II scanner but it said that there were no codes. Did I scan it correctly? Is there a different connector other than the one under the driver's side dash? Is there a special way to pull the codes when its a transmission problem? I'm stumped...
Old Aug 5, 2004 | 09:58 PM
rvfiver's Avatar
rvfiver
There are more safistacated scanners on the market that may be able to pull the codes. However it sounds to me that you may want to take it to a transmission shop and have it diagnosed. Once you are able to clear the codes the transmission may revert back to shifting properly. But that will not cure the problem if there is one. The transmission shop will be able to narrow the problem down.
Old Aug 5, 2004 | 10:13 PM
99f250's Avatar
99f250
Cool
had the same problem about a year ago @ 77,000 miles. time for new tranny!
Old Aug 5, 2004 | 10:30 PM
drembedded's Avatar
drembedded
Say it ain't so. I was hoping that someone else had seen the same problem andit turned out to be the speed sensor or something minor. If the OD light blinks shouldn't the Check Engine Light (MIL) also turn on?
Old Aug 6, 2004 | 06:09 AM
spitball's Avatar
spitball
Try running the codes on it again. I have a diablo predator reprogrammer that picked up the code at once, where my mechanics could not read it. It ended up being the torque converter clutch selenoid pack, 224 bucks and easy install. I had the same symptoms you had, even the flashing light. My predator had paid for itself just with this, it tells me even the exact code and what the code is in detail. Pretty cool gadget plus gives you tha POWER.
Old Aug 6, 2004 | 11:53 AM
drembedded's Avatar
drembedded
Spitball, thanks for the good news. I'm hopeful that my problem is that simple. Did your check engine light come on as well as the flashing OD light? I've borrowed absecond scanner and it also says that there are np codes.
Old Aug 7, 2004 | 06:27 AM
spitball's Avatar
spitball
Yes, I believe it did. Good luck with it...
Old Sep 12, 2004 | 11:09 PM
stroken444's Avatar
stroken444
the exact same thing happend to mine and it was a bad torque converter
Old Sep 12, 2004 | 11:17 PM
drembedded's Avatar
drembedded
stroken444, After not being able to pull any codes, I took it to a shop where they plugged their MT2500 Snap-On scanner to it. There were at least 4 error codes. Are some analyser/scanners better than others? I ended up having the transmission rebuilt and a new billet torque convertor put it. So far we've put 1500 miles on it and we're very happy with the work. The trans has firmer shifts. Lets hope this transmission will go farther than 62000 miles this time. I dropped $3500 on this tranmission and torque convertor and I'd hate to have to do that again any time soon.
Old Sep 13, 2004 | 12:25 AM
allisonta's Avatar
allisonta
YES, some scanners are better than others and that snap-on MT2500 in my book the best you can buy, thats why they cost over thousand bucks.
Old Sep 13, 2004 | 08:45 PM
stroken444's Avatar
stroken444
good deal well i hope you get farther than 62000 miles too but mine didnt show any codes either...
Old Nov 11, 2009 | 08:19 PM
Fiddle's Avatar
Fiddle
sounds like the neutral safety switch needs to be changed, is located on the transmission.
rockauto.com
they have it for 50 bucks
Old Jan 25, 2010 | 09:00 PM
dustmaker37's Avatar
dustmaker37
Hi,
I have a 2001 F-250 7.3 powerstroke diesel and my overdrive button was flashing after i worked it alittle when i had to pull my wife out of the snow. The trans temp was about 134 degrees so i let the truck sit for about ten minutes to cool down then turned it off and back on to see if it changed and it did. The light stopped flashing. Did i just over heat it or is something seriously wrong?
Thanks
Old Jan 25, 2010 | 10:57 PM
onelionhunter's Avatar
onelionhunter
DSS
Might have just been yout DSS sensor on the rear axle unhappy. Is it shifting OK? Does your speedo work now?
Old Jan 25, 2010 | 11:04 PM
Two by Ford's Avatar
Two by Ford
It happened to me a couple years ago. Like you no codes when I took it to the tranny shop. Did it again shortly after I had the tranny fluid changed at the dealer. Went back to the tranny shop and they suggested that the dealer was power flushing and moving chit around in my tranny. They dropped and cleaned the pan, changed the filter and refilled. No problems since then.
