Towing trailer
Old Jun 18, 2018 | 05:26 PM
Travhills's Avatar
Travhills
Towing trailer
I have a 2000 Excursion with a 6 prong plug. I want to change it to a 7 prong and install a trailer brake controller. Is the trailer plug recpt. connection at the rear (plug-in)? If so, are they available at Rock Auto or Amazon or dealer only? Any recommendations for a brake controller & wiring would also be appreciated.
Thanks
Old Jun 18, 2018 | 10:54 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Tekonsha P3 for the controller. There is a plug behind the dash for the controller if it has never had a controller on it. It is above and to the right of the go pedal. You can buy the Ford adapter for the Tekonsha for very little money.
I've never seen a 6 prong on an Excursion.
Old Jun 19, 2018 | 07:25 AM
pirate4x4_camo's Avatar
pirate4x4_camo
I’ve also seen the ford adapter brand new in a bag sitting in the jack compartment, None of the owners ever installed it. Worth a look.
Old Jun 19, 2018 | 08:28 AM
96firephoenix's Avatar
96firephoenix
Tekonsha has one with the same internals as the P3 just without the fancy display, and this listing includes the ford adapter. Tekonsha has one with the same internals as the P3 just without the fancy display, and this listing includes the ford adapter.
The newest model is the Primus IQ. I've got it on my explorer, and as soon as I have 20 minutes to spare, It will be going into my excursion.
Old Jun 19, 2018 | 09:02 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by Travhills
I have a 2000 Excursion with a 6 prong plug. I want to change it to a 7 prong ...
Are you sure it's not a 7 prong plug?
There are 6 prongs in a circle and the 7th is a center pin.
Old Jun 19, 2018 | 05:04 PM
EMC V10 X's Avatar
EMC V10 X
I have never seen a stock truck with a 6 pin. It is a very odd trailer connection. 6 pin has 5 round pins around 1 round center pin. The seven pin had 6 "blades" and one center pin. The 7th pin adds reverse lights.
Old Jun 21, 2018 | 09:21 AM
Travhills's Avatar
Travhills
Thanks for the input. My son has a Tek. I can use, just have to get the adapter & bracket. Definitely a 6 plug, the previous owner, my dad, all his trailers were 6. He bought it new so he must have ordered that way.
Another issue is mirrors. I need wider ones. Any recommendations?
Thanks again
Old Jun 21, 2018 | 09:50 AM
ArmyLifer's Avatar
ArmyLifer
There are many posts on towing mirrors. Here is a more recent one: https://www.ford-trucks.com/forums/1...endations.html
I just finished the install of 08 style mirrors on my excursion from 1AAuto: https://www.1aauto.com/ford-mirror-p...9/i/trmrp00019. Wiring up the turn signals and marker lights were a minor PITA, but the mirrors have a much better blind spot mirror than the OEM tow mirrors.
srb1194
2004 - 2008 F150
Jun 14, 2016 03:54 PM
bigsbetter11
May 22, 2013 07:04 AM
AFoster1025
Aug 24, 2011 06:32 PM
TheTowingCowboy
Mar 28, 2010 11:46 PM
62BigBlue
Mar 25, 2003 04:07 PM
